Old 02-23-2005, 11:50 AM
crv-tec crv-tec is offline
Odd squeek
Ok, so last night on the way home from work I started noticing a odd squeek from my engine. When I got home I learned that it was coming from my dizzy. Well as I oulled off the cap and everything, there was nothing wrong with it. I checked the set screw and it was still in stuck in there with threadlock (just installed cap, rotor, plugs, and wires in a failed attempt to pass emissions). Being as it was 11:30 at night, upon noticing everything was fine, I put it back together. Well as I started it this morning, the noise continued. Well as I started driving to work, it went away. Any ideas?
'nuff said
Old 02-23-2005, 03:56 PM
Re: Odd squeek
On my lunch break I went back out to check it out and found it was still making the noise. The only thing that changed was the rotor. Orginally it just had two parts coming off the part the held the screw on. This new one was bascially a disk with two parts raised where the old one had the two parts coming off....
'nuff said
Old 02-23-2005, 08:46 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Glad u figured it out.... I was gonna say it was gremlins
Old 02-23-2005, 08:59 PM
Re: Odd squeek
Actually it's still making it. I've been leaning towards having the wrong rotor but am not quite sure... never had to work on a distrubter/ignition system before....
'nuff said
Old 02-23-2005, 09:46 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: Odd squeek
Hey aftermarket dist and rotors never really fit right. I got a set from autozone and they did the same thing. So I went to honda paid honda prices but I know its right and it doesnt do it anymore.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 02-23-2005, 09:50 PM
Scott82 Scott82 is offline
Re: Odd squeek
Does is squeak all the time or intermiten? like squeeeeeeeaaaaaakkkkkk or squeak, squeak?
Old 02-23-2005, 09:53 PM
Re: Odd squeek
It squeeks intermiddtenly, as I accelerate the squeek will get quieter and eventually go away, but as the motor goes below 2.5 it comes back. Its just one long squeek...
'nuff said
Old 02-23-2005, 09:58 PM
88ReX 88ReX is offline
This sounds similar to a situation I had with my distributor before it went out. The squeek was rather intermittent and eventually it just started squeeking all the time lightly and would disappear sometimes when I would rev. Anyways back to my diagnosis. On my distributor it ended up being the little bearing on the shaft that the rotor mounts to. The bad news is that its in a part of the distributor that is labeled as "do not disassemble", so I take that to mean don't mess with it and even if you do there won't be a part at honda you can get to replace it with. The good news is I come on this forum and give you the info for free before your dist goes out and you get stranded like I did.
Edit: get a new dist
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 02-23-2005, 10:03 PM
Re: Odd squeek
that's what i was getting at withthe constant squeak. If it is all the time it more than likely a bearing.
Old 02-24-2005, 04:07 PM
I hate when you people are right... that shit aint cheap....
'nuff said
