Old 02-23-2005, 11:16 AM
pacjltd pacjltd is offline
No Start, no Insterment panel gages work?
My Jeep just died. It has power turns over but no start. The insrument panel gages do not work...
Any Ideas...
Thanks,
Steve
Old 02-23-2005, 11:23 AM
JDPascal JDPascal is offline
Re: No Start, no Insterment panel gages work?
check for spark??
Pull a plug wire or the coil wire and hold it near the block, leaving a small gap while someone cranks the engine.
no spark - check the cam position sensor or the crank position sensor.
JD
Old 02-23-2005, 11:28 AM
Re: Re: No Start, no Insterment panel gages work?
Originally Posted by JDPascal
check for spark??
JD
Thanks for the reply!
I have spark, the engine turns over no problem. The gages on the instrument panel do not work. But it diplays millage... I looked and fuses seem ok, so could this be a fuel pump??? I am at a loss what to do next...
Any Ideas?
Thanks again,
Steve
Old 02-23-2005, 06:03 PM
If you have spark, the next likely cause is fuel for sure.
The fuelpump relay could be the culprit. It is in the powerdistribution center under the hood.
Or it could be the pump.
Can you hear the pump running when you first turn the ignition key on? Listen with the door or window open.
JD
Old 02-23-2005, 06:46 PM
Dale Aeppli Dale Aeppli is offline
Any Ideas...
Thanks,
Steve
CHECK IN THE POWER DISTRIBUTION BOX UNDER THE HOOD IN BACK OF BATTERY. THERE IS A BLUE 15 AMP FUSE,IT CONRTOLS FUEL PUMP AND DASH GAUGES IT'S IN THE MINI FUSE SECTION. IF YOU EMAIL ME I'LL SEND DIAGRAM OF 97 BOX DALE
[email protected]
