Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 02-23-2005, 10:55 AM
jkeller1 jkeller1 is offline
Intrepid Belt and Hose Change
I have a '99 Intrepid, and want to replace the belts and hoses. How does one get access to the belts and tensioners? There is no room to swing a wrench down there. Does the cross brace above the radiator come off? Or do I have to work from below. The Haynes manual is absolutely no help.
Old 02-23-2005, 02:39 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Intrepid Belt and Hose Change
your assumption is correct, you have to remove the radiator crossmember to gain access to the belts and hoses.
Old 02-26-2005, 09:48 PM
1thunder 1thunder is offline
You do not have to remove anything to access the belt you do it from the top it is a little tight butyou can do it i have done it plenty of times
