Old 02-23-2005, 04:35 AM
jestersrain's Avatar
jestersrain jestersrain is offline
Send a message via AIM to jestersrain
Unhappy crx KIA
ok so the other day i was driving home from work and the timing belt broke and the car died...because the water pump went out and stuck so the belt broke...now i know how to replace the belt and pump but how do i know if everything is alined right. i know that the cam gear has 2 notiches that line up with the head so i can put that in the right place but what about the crank shaft and pistons how do i find where to turn it to to line everything back up??? p.s. befor i knew it was the belt i tryed to start it so i know one part of the motor turn and the other didnt. its gonna cost me 800 to hav it fixed but if i can do it id love to know how.
Old 02-23-2005, 09:41 AM
Dastreetracer's Avatar
Dastreetracer Dastreetracer is offline
Re: crx KIA
ok to line it up take out all the spark pluggs and pul a screwdriver in the hole that is farthest to the right then turn the crank untill you feel the piston go all the way up then thats top dead center for the crank then the cam shaft has a notch like u said but after you do all that it should be all lined up so just put the belt on and fire it up pm me back for any questions..
Old 02-23-2005, 07:04 PM
Re: crx KIA
ok ill try that soon thanx
Old 02-23-2005, 07:08 PM
pauls81sc pauls81sc is offline
Re: crx KIA
dastreetracer has it basically right, but after you bring the #1 piston (furthest right when looking from front of car) to TDC, you need to be sure you are on the compression stroke. take off the distributor cap and make sure the rotor is pointing to the #1 cylinder. if it isn't, turn the crank one full revolution and that'll do it.
P.S. you can also set the #1 piston to TDC by looking down the notches on the timing belt cover. there are two of them that kinda look like gunsights. if you sight down them theyshould be pointing to a small mark on the left most side of the crank pulley. but you still have to take of the dizzy cap and make sure you're on the compression stroke.
good luck
1989 CRX Si (commuter)
1981 Porsche 911 SC (weekend TERROR!!!)
Old 02-23-2005, 07:16 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: crx KIA
Correct me if I am wrong, but if the timing belt broke while driving (depending on the speed), there maybe some bent valves and shit right. You might want to get the engine checked out first. Thats what I was told when my timing belt broke. Only thing is, it broke in my driveway, so mines was fine.
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 02-23-2005, 07:38 PM
88ReX 88ReX is offline
Re: Re: crx KIA
You are correct sir, if there was any kind of load on the motor at all when the timing belt failed then there is a great possibility that you have bent valves and possibly damage to the pistons. You certainly should pull the head off and inspect before you go any further.
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 02-23-2005, 07:42 PM
T-Mo's Avatar
Re: crx KIA
^^^^thats madam
'93 Honda Civic EJ2
Old 02-23-2005, 07:59 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: crx KIA
yup. when my stock motor broke the timing belt, it bent a few valves
Team Lonely Drivers
Old 02-23-2005, 08:00 PM
Re: crx KIA
god damn it ok.....if they r then thats the end of this crx and will be parting it soon for giving me so much truble
Old 02-23-2005, 08:17 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
if the motor is fucked y dont u jus replace it instead of junkin a nice rex?
it jus seems dumb to do for somethin so easy to fix....jus my
Old 02-23-2005, 08:31 PM
Re: crx KIA
thats true but i have so much hate for this car i was saving for a b18c swap and all but i think ill just find a new car and do something to this one
Old 02-23-2005, 08:42 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: crx KIA
where you live jestersrain?
1991 Honda Civic DX Sedan
Old 02-23-2005, 10:12 PM
Scott82 Scott82 is offline
Re: crx KIA
Sounds like a real good time for a motor upgrade man!!
Old 02-24-2005, 05:13 AM
Re: crx KIA
i live in sacramento cali....i dont hav time for a swap now i need a car by friday when i go back to work and also i live in apartments so pulling the head off the motor is out dont hav the time or place to do it. i needed to be able to fix it in a day. im gonna try to fix it with out checking the head but what are some things i should look for if i get it fixed and the valves are bent or damaged what would go wrong or happen.
Old 02-24-2005, 07:20 AM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Re: crx KIA
how much for your CRX shell if you sell it? Im in Orange County :-D
Travis
