Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 02-23-2005, 01:51 AM
mooseger mooseger is offline
Unhappy 96 tracker wont turn over since I replaced the head gasket??
I replaced the headgasket put it all back together and Nothing.I have dash lights gauges,radio,heater, can hear fuel pump run but try to start it and nothing.Doesnt turn over.Do I need to some how reset the cump. if so how?????? I unhooked the pos.battery post before I started to tear it apart.What am I missing???????A wires seem to be pluged in. Battery is good.HELP PLEASE I don't want the nitemare of tearing it apart again to redo every thing.
Old 02-23-2005, 02:26 AM
89ssgti's Avatar
89ssgti 89ssgti is offline
Do you have a signal at the starter when you crank the key?
Are you able to manually rotate the engine(with a socket on the crank pully)?
And are you sure the timing belt is put on correctly?
Proud member of AF's Lazy crew
Snow,snow let it snow
Af Nordic crew #008
team drift cat official member#5
Originally posted by sparq
CANADA RULES :finger:
CANADA RULES -- thats all that matters :ylsuper
Old 02-23-2005, 08:11 AM
Re: 96 tracker wont turn over since I replaced the head gasket??
Yes it turns fine with socket on the crank.timing belt can be twisted about half twist.I dont know about the starter.If i turn the key to start i have everything inside working normal but nothing under the hood but the sound of the fuel.TY for your responce.
