Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-23-2005, 12:13 AM
98AUR0RA 98AUR0RA is offline
Send a message via AIM to 98AUR0RA
Windows jam
I just noticed that all my windows except the drivers wont go down. there is power to them i hear noises when i push the buttons but they wont go down. What would cause them all to fail at one time? could it be loose wire? Fuse?
Old 02-23-2005, 04:19 AM
Isnibs's Avatar
Isnibs Isnibs is offline
On the drivers door controls. Do you have a 'windows lock' toggle switch?
1996 Aurora Black / grey
Old 02-23-2005, 11:49 AM
Re: Windows jam
yes and its in the off position. and with it on i could always make them go down with the driver button
Old 02-23-2005, 02:07 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Windows jam
have you tried the controls on the other doors? If it's a fuse, the driver side wouldn't work either. I'm thinking there's something wrong within the controls themselves.
Old 02-23-2005, 02:29 PM
Re: Re: Windows jam
yes i tried all the controls when i push the button the window makes a noise like it wants to go down but its jammed. How can 3 out of 4 windows do that at all the same time. is there a fix to this?
Old 02-26-2005, 10:46 AM
oldzgirl oldzgirl is offline
Angry Re: Windows jam
I don't have the answer for you but I can tell you that I have a 2001 Olds Aurora and my problem started with the rear driver side window and now has moved the the passenger window. I only have two windows that roll down. I wish you good luck figuring it out because we haven't been able to.
Old 08-19-2005, 09:54 PM
rwagoner56 rwagoner56 is offline
Re: Windows jam
Same problem with my 2001 power windows. Started with the front passenger side. Now the rear passenger side won't work. To make things worse now it is slipping open. Great. I'm not looking forward to pulling off the door panels.
Old 08-21-2005, 07:57 PM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Re: Windows jam
I think your question should have been: "Have you tried rolling the windows down from the drivers door. And, have you tryed all the controls at each door. Door lock button, would only diable the controls at each of the door besides the drivers.
Old 11-05-2006, 10:48 PM
Ronnie Hampton Ronnie Hampton is offline
Re: Windows jam
I have a 2001 Aurora and both rear windows are jammed. My auto mechanic said that the guide wires are broken. The cost to replace each window is over $400 a piece. Is there a better way?
