Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-23-2005, 01:11 AM
98AUR0RA 98AUR0RA is offline
Send a message via AIM to 98AUR0RA
Check engine
What does it ean when the check engine light blinks?
Old 02-23-2005, 05:21 AM
Isnibs's Avatar
Isnibs Isnibs is offline
I understand it to mean 'intermittent missing on one cylinder'
If so you need to get scanned could be plugs / wires maybe coil.
1996 Aurora Black / grey
Old 03-02-2005, 07:29 AM
The Rebel The Rebel is offline
Re: Check engine
You want to get this checked asap! The check engine light whether blinking, on steady, or (comes on for a moment then turns off) says that there is a problem.The drivability dept. will check the codes, then go from there.
Sometimes, if you talk to the service manager, and ask if they will apply the first hour to the "job" (after they scan the ECM). Also, you don't have to have the work done where the scan was done. They will charge an
hours time to scan the computer for codes.
