Old 02-22-2005, 11:44 PM
Stiletto Stiletto is offline
anti freeze going into engine oil sos
hello ! i have a 99 4.3 blazer it has been losing anti freeze lately. i checked engine oil and it seems the anti freeze may be going in there because the engine oil dip stick is reading higher and higher EH BOY! HELP PLEASE ANY IDEAS ?THANKS STILETTO
Old 02-23-2005, 12:07 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: anti freeze going into engine oil sos
Is the oil milky?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-23-2005, 12:24 AM
it is very light in color so the gm red anitifreeze mixing with brownish tan oil maybe is lightening it ? as for milky do i need 2 touch it or would it look as u say ? milky ? not sure what if milky would look sorry! Stiletto
Old 02-23-2005, 01:38 AM
BlazerLT's Avatar
AF -Advisor
Does it look like chocolate milk?
Cloudy? Can't see through it?
Post a picture of it.
Old 02-23-2005, 06:32 AM
ricksza's Avatar
ricksza ricksza is offline
If the coolant level is dropping and the oil level is going up, I think we know why. The only question is where.
Was the antifreeze strong enough for the winter weather? If so, I would lean towards the intake manifold gasket with a possibility of a bad head gasket. could also be a cracked oil cooler in the radiator. If it wasn't strong enough, Possible cracked head or block.
Old 02-23-2005, 11:29 AM
tom3 tom3 is offline
Our 01 Blazer started doing this at 12K miles. Really didn't see any thing positive in the oil except it was getting a little overfull. I think the high engine temps and the strong PCV system tends to evaporate and pull out the water. Might look under the oil fill cap for moisture. By all means, get the oil changed soon, with the engine hot, and watch what comes out the drain. Probably look like kerosene and have steam coming off it. I'd guess it's time for intake gaskets. We took ours to two different dealers and the only repair we got was the addition of sealer to the coolant sys. (This will be our last new GM product by the way, sign me disgusted)
Old 02-23-2005, 07:54 PM
Thanks GUYS! yep it's cloudy and chocolate milk looking. sorry no digi camera but my love goes back 2 dealer 2morrow 2bad it has everything cd.cassette sunroof 4x4 2 door .compass if cracked block a guy @ work said it is a $3K FIX IT;S UNDER WARRENTY SO WHAT'S THE CHANCE THEY WOULD FIX IT AND GIVE ME HER BACK MY 1ST PAYMENT IS IN 2 WEEKS THINK 9IT WOULD BE FIXED HOW LONG ?? APPROXIMATELY THANKS STILETTO
Old 02-25-2005, 09:51 PM
ding ding ding we have a winner 1st look mechanic thinks it's a intake manifold gasket blown interenally but they are going to take apart and investigate , any idea what causes this? it has 84 k on the odemeter have a great weekend Stiletto
Old 02-25-2005, 10:01 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Re: anti freeze going into engine oil sos
DexCool
Old 02-26-2005, 12:42 AM
Bodaggit Bodaggit is offline
Send a message via ICQ to Bodaggit
Re: Re: Re: anti freeze going into engine oil sos
Originally Posted by blazee
DexCool
DexCool? How so?
Old 02-26-2005, 02:00 AM
BlazerLT's Avatar
AF -Advisor
DexCool
No, Dexcool doesn't eat out gaskets like that.
Old 02-26-2005, 06:03 AM
ricksza's Avatar
Have had some problems with the intake bolts loosening up causing the gaskets to start leaking in the corners.
Old 02-26-2005, 07:22 AM
blazee's Avatar
Problem?
Re: Re: Re: Re: anti freeze going into engine oil sos
Not according to Ford, lots of mechanics (including a lot of GM mechanics)and the thousands of people who are sueing GM.
Old 02-26-2005, 09:08 AM
lou S. lou S. is offline
The gaskets are made out of a phenolic material---not real long lasting and have been known to have a problem with temperature extremes(hot vs. cold).
Old 02-26-2005, 10:06 PM
If you look at the intake you see the bolts don't pull the manifold against the head, they go straight down. The torque on those bolts is very low and the intake sort of floats on the gasket. Pretty much an epidemic of GM cars with intake gaskets leaking these days. Mechanics are building up a good retirement with this repair, about like the Ford head gaskets a couple years back. Nice to see your dealer is going to do it right for you. Guess there are a couple good ones left. Just not around here.
