Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-22-2005, 10:07 PM
TracyM TracyM is offline
How long do rotors last?
Hi,
I just found this site. I have a 2000 grand jeep cherokee that stinks.
I had to have the rotors resurfaced at 13,000 miles, along with new pads. Now at 46,000 miles they are warped again. I've had 3 other suvs that I kept for 100,000 miles or close to it, all other brands, and not once had a problem with rotors. Now with this Jeep I'm having problems twice already. Can anyone tell me how long rotors last under normal city driving conditions. Not in stop and go traffic? It seems to me that they should last longer than they have. I need a reply so I can argue my point with the dealership. Thanks for any help.
Old 02-22-2005, 10:59 PM
JDPascal JDPascal is offline
Re: How long do rotors last?
Welcome Jeep forums.
There are a number of factors that affect rotor life so you shouldn't get to heavy on the dealer.
The fact that they have been turned is a strike against them staying straight in the first place.
There simply is not enough metal even in new rotors to allow them to keep their strength after turning - especially the composite rotors(steel centers and cast wear rings).
What condition are the caliper slides in? Were the wheel nuts torqued evenly and correctly at every wheel removal? Both of these can affect the warping of rotors.
I guess I am not being as encouraging as you may have hoped but Jeep is not the only make that has problems in this area. It does not help when shops recommend or proceed with repairs that will not last.
If it was this dealer that turned the rotors at 13K and it was not explained to you what turning might do to the rotors then that may be your best hope at this time.
All this is aside, other causes may be contributing to the situation as well.
JD
Old 02-22-2005, 11:15 PM
mx52nv's Avatar
mx52nv mx52nv is offline
mine gets wheeled regularly and I average 30-40,000 between rotor/pad changes. if you live in a hot/rainy climate, you get a lot of hot rotor/cold splashing water that can warp them. but on top of that, rotors are NOT a dealer warranty item. just go down to your local Checker or other Raybestos parts distributor and pick up the lifetime pads and rotors.
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 02-23-2005, 01:13 AM
porscheguy9999's Avatar
porscheguy9999 porscheguy9999 is offline
Send a message via AIM to porscheguy9999
What I dont get is how could your roters only last 13,000 miles? Unless you go alot of hard braking, or ride the brakes alot, that just doesnt seem possible. If the problem is truly not your fault, then I think it would be just faulty brakes. Twice seems nearly impossible. My 95 GC has the same brakes that it did when it rolled off the assembly line. And it stops great for 10 year old pads and discs. But then again, I baby my Jeep like none other, which means I brake as little as I can. But if you want to replace the brakes with aftermarket ones, you cant go wrong with Brembo.
Currently:
1998 BMW 328is black/black coupe 5MT
Thanks to Nicecar!
Got a Facebook? Join the AF group!
http://hs.facebook.com/group.php?gid=2213949483&ref=mf
Old 02-23-2005, 06:31 AM
rotors
Thanks for the replys. I feel that I am a decent driver. I don't drive double footed and not real fast so I have to break all of the sudden. My sister had also purchased a Jeep at the same time I did. She too had problems with her rotors at the 13,000 mile mark. She sold her jeep after 1 year because of all the problems she was having. I too have had other problems that took them some time to figure out. Four visits for one of them. I kind of feel like I might have a lemon. I'm getting ready to head to the dealershiip today. Should I have them turn them again or tell them to replace them? I wish I could do the work myself but I'm just no good in that area. It still seams like they were faulty from the get go warping at only 13,000 miles.
Old 02-23-2005, 08:00 AM
mikec041 mikec041 is offline
My wife's 99 GC rotors warped out @ 8k and about every 8-10k after that. The dealer kept swapping out the rotors with new ones until 36k when he said warranty expired.
Replaced them with slotted rotors and have about 50k on them with 1 warp out (had tires replaced and tire jockey didn't torque wheel down).
BTW i had a 93 GC never had problem with rotors until they were replaced under a recall and they wore out in under 15k.
My 04 Dakota's rotors warped @ 13k
See a pattern here?
Old 02-23-2005, 10:36 AM
I just came back from leaving my jeep with the dealer. I waited there until they came back with a diagnoses. He said they will resurface the rotors at no charge. The break pads are still good. The back breaks however need to be replaced. At 47,775 miles that is understood. I asked why the rotors keep warping. He gave the explanation of if you make a sudden stop just even one time, that could cause your rotors to warp. I don't think I exactly believe this. But that was all he was offering. After I got home I looked back at my records. Should have done this before I went. At 16,099 miles the dealership resurfaced front and rear rotors. At 34,841 miles the dealership replaced the front brake calipers, rotors and pads. At 47,775 miles (today) the dealership is resurfacing the front rotors. So about every 13,000 - 18,000 miles I've had problems with the rotors. Could it be possible that the year of my jeep (2000) there was something wrong with the braking system that involved these parts? I wonder if they just put the basic rotors on? Should I insist that they put a different type on with more ventilation? I guess I can probably count on seeing them in another 14,000 miles. I just don't know what to ask them that will satisfy my question WHY DOES THIS KEEP HAPPENING!!!! They don't give me an adequate answer. The head of the service dept. just brushed me off on the phone saying its not under warranty and it's the way you drive. The heck it is. I never had a problem with any of my other vehicles. All at or close to 100,000 miles. Not one time! I don't drive any different and live in the same area almost exactly. Thanks for letting me vent. Phew!
Old 02-24-2005, 12:06 PM
mx52nv's Avatar
might be a good time to learn how to do your own brake job. not hard and will save a bunch of money. there is a reason I avoid the Stealershiip at all costs, all they want is YOUR money. the techs down at Jeep hate it when I can diagnose a problem.
current rides:
1990 Turbo Miata
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Old 02-24-2005, 10:27 PM
glennco1 glennco1 is offline
Tracy, if you look at other posts here, you'll see that WJs are notorious for the warped rotors deal, and a few mechanics have said that Chrysler has done a lot to try and take care of it with no luck. This is why your dealer keeps on fixing it. I believe the warranty doesn't even cover the brakes beyond 10,000 miles.
But one thing I've heard over and over. Whenever you take off a tire, make sure you use a torque wrench to torque all the lug nuts down to the specified torque. (I've heard that this is the biggest thing you can do to prolong the life of the rotors on these Jeeps)
Others have replaced their rotors with higher quality ones and have had better luck.
Old 04-05-2005, 01:10 AM
knate24 knate24 is offline
This issue has been resolved!!
You've probably found by now many follks griping just like us. I had the same issue with my 2000 GC. Without going into details, 'cause there's nothing you can do to save your brakes from this happening agaian and again if you stick with oem replacements. You must upgrade the rotors slotted or slotted/drilled to dissipate the heat and use heavier duty pads. And also use steel rotors, one-piece. There have been a few technical bulletins put forth, if you search you'll see the numbers. But, I'm just gonna break it down like this...The caliper design creates a wave, different than typical warping, preventing and adjustments to them. That is, compounded with the two-piece rotor design (steel hub and composite rotor) that molds to this pattern under the heat stress. After reading many many posts, I feel that my suggestion will significantly increase the time I will continue to like my JEEP>
Old 04-05-2005, 07:54 AM
kljgc kljgc is offline
There is a DaimlerChrysler class action lawsuit about this.
The contact I saw was Lenexa lawyer Michael Hodges at 913-888-7100
Old 04-05-2005, 01:00 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
I believe the problem is with the caliper. It has two large pistons and applies a lot more force to the brake pads and rotors. I found that replacing the rotors with Bendex suv rotors will help extend the life of the rotor. The Bendex pads last forever, I've had the same pads and rotors for over 45K on my YJ running 33 inch tires. Try the Bendex
Old 04-05-2005, 10:15 PM
Jeep6855 Jeep6855 is offline
Send a message via MSN to Jeep6855
Grand Cherokee Brakes
I have the same problem with my brakes. On my 2004 Grand Cherokee, the rotors warp every 6-8,000 miles. I now have 26,000 miles on my Jeep and the rotors are warped for the 4th time. Seems like when I take a long trip, drive for 250+ miles without stopping and then braking, the rotors are warped and they seemed fine when I started the trip. I also had a 2002 Grand Cherokee and never had any rotor problems. I know of 2 other Grand Cherokee's that have similar problems and both as mine have the chrome wheels. My 2002 and another friend who has a 1999 with no problems have the standard wheels. I know that the type of wheels shouldn't make the rotors heat up, but does make me wonder a bit.
Old 04-05-2005, 11:48 PM
#1 cause of rotor warping is incorrect torquing of the wheel nuts.
second to that is corrosion/dirt on the wheel mount surfaces when the nuts are tightened.
Rotors with a stamped steel center are more sensitive to this mishandling.
Another thing that happens that mimics a warped rotor is the result of stopping when the rotors are hot and a small amount of pad material sticks to the rotor creating a high spot when the parts cool. Again, some pad materials are more prone to this than others.
A seized piston or sticky caliper slides will add heat to the rotor and pads by not retracting when the brakes are released. This places a side force on the rotor and it cools in a warped position.
Many owners miss the relation ship of warped rotors and the fact that they just had tire work done on their vehicle. Tire rotations, flat repairs and seasonal tire changes are all opportunities for the improper tighteneing of wheel nuts.
The small $ invested in a click type torque wrench with a range of 20-150 ftlbs is worth it so you can double check the work of the tire shops. It should save atleast some of the rotor failures that people experience.
JD
Old 04-07-2005, 11:06 AM
Re: Re: How long do rotors last?
Of course those are all true statements. You seem to know your stuff. Your explanation helps ereryone to understand the root causes of the GC front brake problems. Except for the wheel torquing, which would only make it worse, the GC's that exhibit the warping have steel center/composite rotors, two piston calipers, and pads that do not have adequate heat dissipation and tend to stick. The system just wasn't designed to handle the way we drive Jeeps. I ordered a set of front drilled brakes and ceramic pads for my 2000 GC just the other day from JCWhitney. I hope a lotta people read this thread, it could save them plenty of $$$.
