Old 02-22-2005, 08:39 PM
redtegb18b1 redtegb18b1 is offline
Send a message via AIM to redtegb18b1
b18 swap question???
Alright so i have a 94 teg and i'm an idiot and lost my license. So i want to start a project while i'm waiting......why not right?!?! I can get a 89' crx si shell for 400$ and i was wondering how hard it would be to put a turbo b18b1 in it.........like can i use my axles off of my teg, and can i switch the suspension out off of my teg onto the crx. I have the tools and the knowledge to do all of this, i have tried reaserching this but cant seem to find a whole lot about it. also what should i do for the shift linkage...buy one or (if possible) use the tegs just "modify" it. ....thanks alot for any info
Old 02-22-2005, 09:08 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: b18 swap question???
you use the tegs linkage, u can use the teg springs, not sure about the struts, youll need aftermarket mounts, obd1 conversion (easier to get a harness to convert) oh and yes you use the teg axles.
1991 Honda Civic DX Sedan
Old 02-23-2005, 10:17 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
it would be easier to get a conversion linkage for you car because the 94+ linkage doesn't work even if you cut it.
No, you won't be able to use the axles. You have to find some from a 90-91 or from a 92-93(non-abs)
you will also need to find a cable bseries tranny unless you wanted to convert your crx to a hydro tranny setup which will set you back a few hundred bucks from hasport (it's not worth it IMO for a hydro LS tranny).
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 02-23-2005, 01:21 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
wrong bambam you can use the 94+ teg axles, you just need to use 94+ axle seals on the tranny.
its pretty much use whatever axles you want 90-93 or 94+, you just need to use the same axle seals
Team Lonely Drivers
Old 02-23-2005, 02:01 PM
DJEuphoriKa DJEuphoriKa is offline
Send a message via AIM to DJEuphoriKa
What's wrong with the integra?
Is your kung-fu strong enough?
Old 02-23-2005, 03:48 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Re: b18 swap question???
Um idunno? The 94 teg axles are shorter 475mm-480mm. While the 2nd gen tegs are 485-490mm. Not much but there better. The 94+ teg ones will work as long as they are matching the tranny.
Old 02-25-2005, 05:28 PM
bambam89lx's Avatar
AF - Advisor
Re: Re: Re: b18 swap question???
I was making that statement assuming he would be using the cable tranny. You don't want to use the 94+ axles if you are going to be using the cable tranny....it would cause (minor) binding problems.
Old 02-25-2005, 07:22 PM
you can, you just need to use 94+ teg axle seals on the tranny so it doesnt leak
Team Lonely Drivers
Old 02-25-2005, 09:25 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Im no b-series expert, but wont the shorter 94+ axles risk slipping out of the knuckles?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-26-2005, 02:54 AM
nope, the hub end of the axles has a axle nut on it. so it wont slip out
Team Lonely Drivers
