Old 02-22-2005, 08:35 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Question battery light blinking
so my battery light on my cluster is liek fading and ocmign bac kalot. and the electrical system has bee nredone. new groudns and wires. new ecu, new alternator and its all fine but the damn light is on. whats the deal
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 02-22-2005, 08:43 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Re: battery light blinking
usually thats a sign of a bad alternator, i would guess you have a bad connection somewhere...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 02-22-2005, 09:09 PM
well i checked all the connections and i knwo its not my alternator becuase i sjut repalced in like a week ago.
06 cbr 600 f4i
91 civic hatchback.
Old 02-23-2005, 04:40 AM
jestersrain's Avatar
jestersrain jestersrain is offline
Send a message via AIM to jestersrain
if you hav masive bump then when ever the bass hits it will flicker or come on my old car did that
Old 02-23-2005, 09:16 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Check the tension of your alternator belt. If it's too loose your alternator won't function properly - causing the battery light in your cluster to flicker.
Also, check the bolts that hold your alternator in place. If they've worked themselves loose, that would obviously cause your alternator belt to be loose...
Old 02-23-2005, 08:46 PM
hmm ok ill check the alternator bolts i think its the bottom one. but the thing is is that the voltage is sufficent its a constant 14 volts about.
06 cbr 600 f4i
91 civic hatchback.
Old 02-24-2005, 05:28 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
put a load on it make sure it stays chargin, n not over charge...alsoif u have a system without a cap. it'll come on if it hits hard enough...
Old 02-24-2005, 08:19 PM
well pretyt much my car electrical is a mess. its not the stuff ive doen jsut the stock wires and the shit itself was jsut a mess ebfore i got it. so im not happy.
06 cbr 600 f4i
91 civic hatchback.
Old 02-24-2005, 08:32 PM
Scott82 Scott82 is offline
Check all Fuses. I had a fuse blow one time that made my battery light come, it was a fuse for some of my warning lights, one of them blew and sent power to another some how. I changed the fuse after checking about everyone in the car and it was fixed
Old 02-24-2005, 09:05 PM
i might do that i mean i got nothing else to do.
06 cbr 600 f4i
91 civic hatchback.
