Go Back   Automotive Forums Car Chat > Mercedes-Benz > General Discussion
Old 02-22-2005, 08:13 PM
Shelbygt350 Shelbygt350 is offline
Question 300D automatic "adjustment"
I am helping my friend with some research. He has a 300D with an automatic tranny. He was told there is a slot where you can insert a flathead screwdriver to modify the shifting. Where is this slot located? I think the car is a 84. Any help would be greatly appreciated. E-mail me at [email protected]
Old 02-28-2005, 06:57 PM
talonlover's Avatar
talonlover talonlover is offline
Re: 300D automatic "adjustment"
probably talking about the modulator valve. You can tone down how hard the transmission shifts by turning out about 1/2 turn(I think it's out, maybe in)and driving it to see how you like it. It's just a trial and error thing and a little bit of driver preference. the modulator valve is probably either red or green on that car so it's easy to spot on the side of the tranny.
1981 Delorean DMC-12 frame off resto. 2006
Old 03-18-2005, 08:11 AM
podunk podunk is offline
Thumbs up Hardening the Shifts
You can pop that red or green cap off and underneath you will find a "T" shaped metal tab in most cases.
Turning the tab clockwise will harden the shift points, but do try small increments of adjustments at a time. The red or green cover has slots around the "ID" that holds the metal tab in place.
Old 03-19-2005, 05:30 PM
j_hef j_hef is offline
Send a message via AIM to j_hef
just remember when you adjust that for softer shifts, you ARE making the trans slip, so do it in moderation.
