Old 02-22-2005, 07:22 PM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
Angry All show no go
I believe the last time I posted I it was because a mustang GT ran over my headlight covers I just brought and then dusted me, Now thinking back losing to a pony wasnt that bad after all.
But today the worst happen I lost a ungly honda accord it wasn't that I couldn't beat it. Once again I fell flat on 90mph. Is this usually with stock 305tbi and how much horse power does it have stock. I believe my transmission is not switching into the gears like it should. I know it jerks when I go in to reverse. Its very dependable but slow. Any advice...Here is a picture of the poor thing.
http://members.cardomain.com/jcutta
Old 02-22-2005, 07:34 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: All show no go
Very nice, clean lookin car there man.. A lot of threads comin up recently about 305's
Do a search for 305 performance and you'l find all your answers..
I guess the first thing is headers, exhaust, and intake..
1991 Camaro Z28
Old 02-22-2005, 07:39 PM
J.Cutta's Avatar
Re: Re: All show no go
How much horse power does it have stock|?
Old 02-22-2005, 07:47 PM
DaMoNe6969's Avatar
Re: All show no go
If its a TBI its got
170hp@4000
255ft.lbs@2400
For the TPI was
205@4200
285@3200
And the G92 TPI's were
230@4200
300@3200
(had a more agressive cam)
1991 Camaro Z28
Old 02-22-2005, 08:11 PM
tc3 tc3 is offline
the 400r4 and 700r4 auto transmissions will not shift into overdrive(4th) gear at wide open throttle, and if the detent cable isnt setup right then it might not shift gears at all at WOT
EDIT: you should take a look at thirdgen.org , the best place ever for thirdgens, tech articles have something about adjusting detent cable if that happens to be a problem
Old 02-22-2005, 09:24 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: All show no go
those 305s can scream if you work em. heads, manifold, cam, headers, exhaust, intake, and they will move. there's a lot more you can do but i dont remember everything. when you run a search look for 92RS's posts. he had his 305 killin back when he was postin...
*Better power-to-weight ratio than a C6 corvette*
Old 02-23-2005, 06:06 AM
J.Cutta's Avatar
Does this sound like the TV detent cable? If i'm going about 40mph and then I decide to floor the pedal..It takes about 4 sec for the engine to respond. Then it jerks forward in to the next gear? How does racing in drive compare to Overdrive.
Old 02-23-2005, 09:30 AM
tc3 tc3 is offline
i guess it could be a cable problem, either way you should fix that anyways, but the difference between driving in drive and overdrive is nothing except top speed, and your car probobly has the 2.73 rear end gear ratios so top speed in third gear would be reached because of lack of power, so its probobly pointless.
some people say that it shifts faster in drive then overdrive, but i think that is bs...
Old 02-23-2005, 09:57 AM
LT1MAN LT1MAN is offline
Banned
Re: All show no go
man im glad i have a 350, im not doggin the 305 lots of you have but my good friend has a 79 black camaro with a 305 and its just to juicy and smooth, no beef you know? im sure you could dump mad change into it too get good results, but if you can afford a 350............
Old 02-23-2005, 01:27 PM
AllGo'n'Show AllGo'n'Show is offline
for a secodn there I thought I was going to be eat'n out again.
Old 02-23-2005, 01:39 PM
tcfco2005 tcfco2005 is offline
Re: All show no go
I have the same car as you and i know what you mean. Ive asked how to get more power for my car also so just go and search the thread for 305tbi and youll find alot of stuff. The main thingns ive been hearing to do to my ride is of course the whole dump the 305 and get a 350 but if you want to keep the 305 you can get World Products Torquer 305 heads. Edelbrock Performer Intake manifold, and a Holley 670cfm TBI. open element air cleaner. Edelbrock TES headers, hi-flow cat, and 3" flowmaster.Trans-go shift kit w/ corvette 1st to 2nd servo.3.73 gears and from what i heard that will get you around the 12's-13's range in a quarter mile
Old 02-23-2005, 02:14 PM
Z28orBUST's Avatar
Z28orBUST Z28orBUST is offline
Welcome to the world of owning a 6 cylinder. My friend had one for a couple years and all he did was get busted on.
Proud Owner: 1994 Chevrolet Camaro Z28 Convertible
Color: Hunter Green
Type: Z28
Top: Convertible
Engine: LT1
Horsepower: est. 275
Mods: water pump, thermostat & gauge, serpentine belt, platinum high performance 100k mile spark plugs, 4 brand new tires
Future Mods: exhaust, headers, sound system
Pics: Coming Soon(can't get this pic going)
Old 02-23-2005, 02:31 PM
Re: All show no go
in my car a 305 is an 8 cylinder
Old 02-23-2005, 02:47 PM
tc3 tc3 is offline
i dont remember if you said anything about what you already done to the car, i see the flowmaster but thats it. My brother has a 1991 rs convertable. the thing would have the worst throttle response ever, even in nuetral. He put a high flow filter on it and it opened it up alot..., then tried to flip the lid upside down(oldschool trick) but the hood doesnt close then.
but basically what im trying to say is if you dont already have one, then get the open air intake...
try this also
also try the other ultimate tbi tech articles at the site above...
Old 02-23-2005, 04:27 PM
Twitch1's Avatar
Twitch1 Twitch1 is offline
Re: All show no go
Just curious- what distance were you running? Was it a standing quarter or a duel at freeway speed for flat out top end? Did the thing have you the entire distance or catch up to you?
My tranny is a TH 400 and and will "thwunk" into gear from neutral as it mates up with the engine speed and brings it down. If there ain't much you can do $$wise flush trans, change filter if it's never been done- 50,000 miles or more- and use B & M Trick Shift. It WILL make it shift better if there's no real problem.
1973 Z-28
1965 Nova
1950 Packard
1996 El Dorado Touring Coupe
There is no substitute for cubic inches
