Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 02-22-2005, 06:00 PM
alexd4488 alexd4488 is offline
Turn signal switch
My turn signal switch no longer shuts itself off. Do I have to replace the whole switch for $40-$50 or is there a part I can replace that will fix this problem? Please help.
Thanks,
Alexd4488
Old 02-22-2005, 07:22 PM
JDPascal JDPascal is offline
Re: Turn signal switch
This probably involves replacing the switch. If you have an air bag, better to get a shop to do it for you.
JD
Old 02-23-2005, 12:15 PM
GreenJeep10's Avatar
GreenJeep10 GreenJeep10 is offline
Sorry I think they are one sealed piece. I just got done replacing my turn signal switch on my 97 wrangler. I had the same problem when turning right it wouldn't shut off. Found a website that told how to do it and it looked easy as pop the old one out a put the new one in........Its alittle tricker than that but still not hard. First remove lower dash srews. Lower dash hinges down but will bind on the head light switch and ignition key ring. Lift the lower dash abit to clear the light switch and if the interior is warm the lower dash will flex enough to get around the key ring. Then remove the 3 screws on the bottom of the steering column. The lower portion of the column will not come off unless you remove the ignition key ring. I was able to leave it on. The top potion is abit of a pain. Lower the steering wheel to increase your area to work. Then move, tweek and jostle the thing outta there. Again a warn intererior will make the pastic alittle more flexable. When you remove that you will notice a rubber rain cover over the hazard and turn signal switch. You need to remove it but be careful. Mine was glued down. I used a puddy knife a carefully scraped it until it was off. I kept it in one peice with a few tears at glue points. The remove the 2 screws one the top of the bracket around the switch, the bottom screw is a T25 torkes. To get to this I used a small ratchet. After the bracket is removed the switch lifts out with the 2 wire bundles in the back still attached. Removed the wire connections and it is completely out. Keep an eye on the cable fot the tilt steering I knocked mine off while removing the top portion of the column. Removing the cable from the tilt handle may give you more room to remove and insert the new switch. To reinstall do the things I discribed in reverese. TEST SWITCH BEFORE CONTINUEING......Getting the top portion is abit of a pain but be patient and you will get it. When getting the lower dash back on hook in the lower hinges and lift up. Again the ignition ring and light switch will bind. Flex the lower dash to the right to get around the key ring and besure that the left side hinges don't come out. To get the lower dash over the light switch gently push on the lower side of the dash and it will flex enough to get around the light switch. Replace screws and you are done. Time for a test drive. I hope this helps anyone who needs to relplace a turn signal switch on 97 and up wranglers.
