Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-22-2005, 04:47 PM
furstmat furstmat is offline
does anyone know why?
I've got a 2000 Honda Civic Lx with a manual transmission and about 90,000 miles. After it runs for awhile, sometimes it likes to stall at stoplights and while I'm coming around a curve and pressing in the clutch. I can tell when it's about to do this because it idles under 500 rpm. Does anyone know why it does this?
Old 02-22-2005, 08:40 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
Re: does anyone know why?
same thing used to happen in mine. pop the hood and take off the filter box (it just slides off fairly easy after you remove the screw on the left side), on the throttle body there is a little black tab, take that off and under it is a flat-head screw. with the car running and warmed up turn the screw ccw to increase the idle speed. should be a quick fix like that, otherwise check out/clean/replace the IACV
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 02-23-2005, 08:18 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
if that doesnt work, check your plug wires, plugs, cap, rotor, vacuum leaks at the fpr, intake mani (kinda extreme, but, will cause it), and go get a valve adjustment if you havnt done it yet at 90k. actually, these should already been done by 90k.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 03-14-2005, 12:14 AM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
learn how to drive a stick
Old 03-14-2005, 05:52 AM
vettemaan's Avatar
vettemaan vettemaan is offline
Send a message via ICQ to vettemaan Send a message via AIM to vettemaan
Re: Re: does anyone know why?
Try and be alittle more constructive with your posts. please.
Old 03-14-2005, 08:48 PM
twospirits twospirits is offline
Ex-Janitor of AF
I agree.
Attention non-contributing member/99redsiverado.
The first quoted post above is in no way shape and form helpful to the original posters question/problem. Post like this can and will start heated discussions that are not needed, tolerated nor warranted in AF.
Please re-read the User Guidelines outlined in my signature. Any further non-contributing post will be removed and if it continues will be given some time off to ponder your actions.
With that said, members please continue with your discussion.
twospirits
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Old 03-15-2005, 12:17 AM
hey im really sorry im having to go through all the forums and figure out where my name has posted shit. some one logged on to my name and pissed a lot of people off..ive been in the hospital since friday...im so sorry
it sounds like you may have an ignition arch somewhere...check all ignition parts, could even be a fuel pump going bad.....
i used to work on a lot of hondas, and that was a frequent concern...also like civicx said, your IAC maybe dirty, bad, or going bad...
again im sorry for the asshole post
hope this helps
