Old 02-22-2005, 03:35 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
wont go into gear while running but...
Well i recently replaced my clutch, and i had no probs with it until today. i went out and warmed my car up and realized it wont get into gear unless i throw all 260pds of my self into the shifter.. but the wierd part bout it is it goes into gear easy when i have the car off what could be the problem? i hope i dont have to tear that shit all apart again!! thanks
Old 02-22-2005, 04:00 PM
Problem solved.. cars been sitting for a week and i started it in first gear and drove it and its fine.. who knows
Old 02-22-2005, 04:32 PM
V-K V-K is offline
Send a message via AIM to V-K
Re: wont go into gear while running but...
I'd be affraid of breaking my shifter if I put all my weight into it lol
Old 02-22-2005, 09:10 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
sounds like you need to loosen you clutch adjuster. mine did this too what happens is the fingers of the pressure plate go too far back and spin the clutch disc, the easiest way to find out is to push you clutch to the floor then pul it back up an inch or two then try putting it in to gear
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
Old 02-23-2005, 12:50 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
same thing happened to me
Old 02-23-2005, 02:05 PM
Dastreetracer's Avatar
Dastreetracer Dastreetracer is offline
you shouls check transmission fluid.
Old 02-23-2005, 02:06 PM
1PhatCX's Avatar
Re: Re: wont go into gear while running but...
whos that refering to?
Old 02-23-2005, 10:29 PM
well i havent made the adjustment yet, but it makes sense to me since i do have the thing damn tight.. and well like i said i recently did the clutch swap and my fluid level should be good.
Old 02-23-2005, 10:32 PM
well i havent made the adjustment yet, but it makes sense to me since i do have the thing damn tight.. and well like i said i recently did the clutch swap and my fluid level should be good. thanks for the tip Steve
