Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-22-2005, 02:20 PM
thole812 thole812 is offline
Overheating
I have a 1995 ram 1500, 360ci. Came equipped with a tranny cooler.I have towed with this vehicle since I bought it new.No problems till a couple of years ago. Started to overheat when towing.Fluid level is okay.Also not getting good heat in winter.
Old 02-22-2005, 04:12 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Overheating
need more info, Is the engine or the tranny overheating?
Old 02-23-2005, 03:22 PM
Re: Re: Overheating
[quote=Austin8214]need more info, Is the engine or the tranny overheating?[/QUOThe tranny light does not come on so I'm assuming it is not.Yes the engine is overheating. The temp needle will just about touch red then I have to shut down.
Old 02-25-2005, 09:52 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Overheating
In that age of vehicle, it's common for the radiator to lose efficiency due to partial clogging. Have your radiator checked by a reputable radiator shop.
Couldn't hurt to check/replace the thermostat and water pump either.
Once those two are done you should see a big improvement in cooling.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-25-2005, 03:10 PM
Re: Re: Overheating
Thanks for the info.
Old 02-25-2005, 09:20 PM
Re: Overheating
Sure thing; post back here if that doesn't solve the problem....good luck.
Old 03-04-2005, 10:44 PM
eskicay18 eskicay18 is offline
Send a message via AIM to eskicay18
Re: Overheating
i had the same problem..itd go up to 250 and not hit the redline yet but one day it overheated and it barey was touching the redline..had it towed and hda a new radiator put in it and a new water pump and a new theremostat, so now its all good...no more overheating...
