Old 02-22-2005, 01:27 PM
jrich057 jrich057 is offline
Misses badly when tranny shifts down
My 97 Sierra pickup 350 V8, auto tranny runs fine at all speeds, but when you press the accelerator hard enough to make it shift down, it starts to miss badly. Acts like it's only running on 4 cylinders, chugs and looses power totally. If you ease up and let it shift back up again, smooths out and runs like a top. You can be running along at 70, come to a big hill and press hard enough to make it drop out of O/D and it misses. You can accelerate normally as long as the tranny doesn't shift down.
Does anyone have ideas or suggestions?
Old 02-22-2005, 02:45 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Misses badly when tranny shifts down
does it do it if you downshift manually?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-22-2005, 02:59 PM
Re: Re: Misses badly when tranny shifts down
Darn good question, I'll find out and post. Thanks for the response.
Old 02-22-2005, 06:00 PM
Re: Re: Re: Misses badly when tranny shifts down
It only seems to do it when you press the pedal hard enough to make it shift down to the next gear. Runs ok if I shift down manually.
