Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 02-22-2005, 11:22 AM
blh1960 blh1960 is offline
95 mystique problems
I have a couple of problems with our 95. Has been a pretty good car. We are pushing 155,000 miles. We have had an interminent (not so interminent any more) engine light come on for over a year now. When you first start the car it usually is not on for 5 minutes or so, then it stays on. Heat related? I have read some threads and suspect a bad CAT. How can I check this? I do not know how to pull codes off of this care since it is the older style.
Also...we discovered in heavy traffic over the weekend that the cooling fan was not coming on. Engine almost got in the red. Looked at it and notice the wiring harness that goes to the fan was cracking really bad. The insulation was coming off the wires. I insulated the best I could with elec tape. Looked at the fuses. Seem to be good. I am leaning towards an coolant sensor. I guess I need to get 12v to the fan and see that it runs. I also have heard mention of a resistor that goes bad on the fan. Any idea?
Another small problem is the cigarette lighter is not working. Need to find the accy fuse box. We tryed to hook the cell phone to it. No power. Any help would be greatly appreiated!
Brian
Missouri
Old 02-28-2005, 08:11 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
There was a recall on the cracking wiring harnesses. I got mine replaced a few months ago.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-03-2005, 08:18 AM
Saskatoonian Saskatoonian is offline
Re: 95 mystique problems
I recently bought a 95 Mystique V6. Quickly discovered that there are two recalls, one for cooling fan related problems, other for converter. Got a new fan/harness and complete exhaust manifold with cat and pipes back to the muffler.
Old 03-03-2005, 10:41 AM
Re: Re: 95 mystique problems
I punched my vin number in at the ford site and says there are no recalls. Did you do it some other place. I also called them. I went ahead and ordered me a radiator fan (aftermarket $155.00). Insulated the harness the best I could. My fan bearings have siezed up. I did get it to come on, but it did not stay. I wonder why it did not show up as a recall. I think my engine light interminently coming on is attributed o2 sensor or CAT. With 89 octane fuel (10% ethenol) it is not coming on as frequent. It is quite obvious the difference. This makes me think the O2 sensor is not putting out a happy signal. It acually runs much better with 89 octane. Interesting!
Old 03-03-2005, 11:12 AM
Re: Re: Re: 95 mystique problems
recall and tsb info at fordcontour.org
http://www.fordcontour.org/forum/index.php?showforum=50
"The CEG Nazi"
www.contour.org
