Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 02-22-2005, 09:15 AM
lorry lorry is offline
Red face No Spark
Well I now know that i have no spark, what is strange is that the car ran fine the night before. Drove to the store and came home and would not start the next morning. I was told that unplugging the computer might work, but am unsure about that. Any ideas what to check?
Have checked distributor and it looks fine.
Old 02-24-2005, 09:55 PM
mazdatech mazdatech is offline
Re: No Spark
2.0L or 2.5L????
Old 02-25-2005, 09:17 AM
No Spark
The car has a 2.5 V6 Any help would be great!
Old 02-25-2005, 09:27 AM
Stryder Stryder is offline
Re: No Spark
u sure u have no spark?...if u have no spark check ur plugs and wires...1st thing to do
Old 02-25-2005, 03:00 PM
Re: Re: No Spark
I took out at plug and turned the car over and see no spark, plus I sprayed liquid fuel into the intake and the car will not fire. I really don't know were to go next.
Old 02-26-2005, 09:43 PM
softball160046 softball160046 is offline
sounds like your ignitor is shot, which is in your distributor
Old 02-27-2005, 11:34 AM
Re: No Spark
Can it go that fast the car was fine the night before? Thanks for the tip
Old 02-27-2005, 04:18 PM
Re: Re: No Spark
yes it happens fast sometimes...bad thing about it is you need to replace distributor which is about $150.00. good thing is its not that hard to replace yourself.
Old 05-27-2005, 11:17 AM
wordwiz wordwiz is offline
Similar Problem
I have a very similar program. A 1991 Mazda 626 LX was running great then died suddenly. No spark. There is juice coming from the coil but not the distributor so it was replaced, along with the distributor cap and rotor. Still no spark. Before it happened, there were no warning lights, no sign of any kind of trouble.
Mike
Old 01-09-2006, 01:19 PM
1badredbird 1badredbird is offline
Re: No Spark
Take your battery & get it checked. Some of these modern imports will not function properly (many different things) if your battery is putting out less than 11 volts. 1st, clean your battery connections (especially the ground), a bad ground can also cause a great deal of strange going ons! Sound too simple? You may be surprized. I had a 96 Chry. Cirrus that went completey, wipers running while switched off-car would not run w/headlights on-severe detonation & more. I cleaned the battery posts & ends, and it cured every problem! Yes, I was schockled dirty batt connections could cause such havoc! Good Luck-Ric
Old 06-23-2006, 11:13 AM
LMP's Avatar
LMP LMP is offline
Re: No Spark
ANy hint about how this turned out to be?
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
