Old 02-22-2005, 08:52 AM
SeaWolf11 SeaWolf11 is offline
95 Suburban abs question?
95 GMC Suburban 5.7L/2wd/AT/4 whl abs. Abs lite comes on/tested found code 68 (pump motor) If I tap on the motor with a plastic mallet it will be ok for a few days than lite will come back on again(same code). The motor is mounted to the valve control assy by 2 bolts. My question is can I remove this motor and repair it or will brake brake fluid pour out all over the place? If not I will just disconnect the thing and be done with it. Don't use it when towing anyway as it increases the stopping distance to much. 33 year Ford Tech here.
Old 07-11-2005, 06:54 PM
keneesha keneesha is offline
Re: 95 Suburban abs question?
i have the same problem what did you do....art
