Old 02-22-2005, 03:26 AM
hootymo's Avatar
hootymo hootymo is offline
Send a message via AIM to hootymo
rear axle bearings, vibration question
what exactly are the rear axle bearings and can they cause vibration at higher speeds? i have a '00 blazer LT that you can feel vibration in the rear at any speed over 40 mph. no vibration in steering wheel and cant feel it that much, but you can definitely hear it and it can be felt more at higher speeds, then kinda goes away around 75 or 80, have had the following fixed to try to stop the vibration:
-checked front hub/bearings, no play
-replaced u-joints
-replaced tires/balanced twice
-alignment done
-checked tie rods/idler arm/front steering components, all tight
-checked, topped off rear diff fluid
-balanced driveshaft
-checked rear wheel bearings, no play
-checked rear/front shocks and springs, were good
so does anyone know what is left to check? im at my wits end with this problem!!
Old 02-22-2005, 04:28 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: rear axle bearings, vibration question
I doubt if it's your rear axel bearings. I would more suspect a bad/bent drive shaft or a bent axel shaft with the symptoms you describe...
Usually with a speed cauised virbration like that I would be looking at the axel shaft. Granted, a bent axel shaft could cause one of the axel bearings to go bad, but it's unlikely.
When they replaced the u-joints, did they replace both or just one?
Also for giggles, I would have the motor mounts checked.
Old 02-22-2005, 07:26 AM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
-replaced u-joints
-alignment done
I know you stated that you already replaced your U-Joints but I'd suspect that they are the culprit. If they weren't installed properly they would cause the very symptoms you are describing.
Old 02-22-2005, 10:16 AM
crazycory1 crazycory1 is offline
It could be the rear. If your truck has a posi in it, the posi could be bad. That was the cause of the vibration in his full size truck. Also if the pinion on the rear has play in it, that might be the problem.
Old 02-22-2005, 10:38 AM
hootymo's Avatar
Re: Re: rear axle bearings, vibration question
they only replaced the rear u joint, said the front one was good.
Old 02-22-2005, 01:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Did any of the fixes seem to make it a little better?
Have you checked your transmission and transfer case mounts?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-22-2005, 09:43 PM
hootymo's Avatar
honestly... nothing has improved it at all. do you think it could really be the front u joint on the driveshaft?
Old 02-22-2005, 09:53 PM
BlazerLT's Avatar
AF -Advisor
What about an alignment?
Old 02-22-2005, 10:31 PM
hootymo's Avatar
yea like i said above i had the alignment done, actually twice already to no avail.
Old 02-23-2005, 03:11 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Could be the inner rear axle bearings. I currently have this problem. The rear hums at higher speeds, but I don't notice any vibration. The hum goes away at about 70.
Old 02-24-2005, 04:21 AM
hootymo's Avatar
i really think its my driveshaft. anyone know where i can get a new one? or can this one be rebuilt?
