Old 02-22-2005, 02:26 AM
ginger666 ginger666 is offline
Steering Collumn Installation Help!!
I have a 1987 Chevy S10 Bazer. The people that had it before me turned it from an automatic to a stick. When they did they decided to have a push start button instead of the original ignition with key. This doesnt work sometimes and I have a new steering column, however I am unsure of how to install it, any help would be awsome!! Thanks So Much!!!!
Old 02-22-2005, 04:45 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Steering Collumn Installation Help!!
Disconnect all wiring along the steering shaft. Disconnect the intermediate shaft at the steering box. Remove the 3 13mm nuts holding the base of the steering column at the firewall under the dash. Remove the 2 15mm nuts holding the steering column to the dash itself, pull out slowly to make sure that you got all the wiring. Install in reverse.
Old 02-22-2005, 04:12 PM
OverBoardProject OverBoardProject is offline
Banned
easy job, just make sure that the columb is the right one. Chevy changes them way to often, and it might just be 1 plug different which will really mess you up
