Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-20-2002, 08:08 PM
vernonhonda vernonhonda is offline
Can I run NOS w/ my turbo??
hi,,,i have a honda civic ex that was rebuilt with spr pistons (9.0:1) ,eagle rods, and a crower cam. I just ordered a fuel rail, pump,regulater, and fuel filter. I will send my ECU out to JET to get it reprogramed. So soon my motor will be complete!!!!
But the question i have is this. With all that done, and me running 9-10 psi turbo,,,CAN I ALSO HAVE NOS. if so, WET or DRY??? WHAT COMPANIES????
thanx for ur time
Old 03-20-2002, 09:52 PM
MadDog06 MadDog06 is offline
Send a message via AIM to MadDog06
all you experts out there don't bitch at me if im wrong but i've heard that you can run nitrous with a turbo; like if you have a big turbo you could spray early to help get it spooled up. im not sure if you'd want to go wet or dry, but since im sure you're not gonna want a big shot you might just go dry. thats just my .02...you can kick me in the balls if im completely wrong
Old 03-21-2002, 10:14 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I'm not sure about hondas but i know that supras needed to do that just to get there turbo spooled quicker in only the 1/4 mile strip cause there turbo kicks late.
Old 03-21-2002, 10:15 PM
VTECseoul VTECseoul is offline
Send a message via AIM to VTECseoul
you need a wet shot & get bigger injectors...330cc fuel injectors & a wet NOS kit.
2000 Honda Accord LX Satin Silver Sedan
AEM ColdAirIntake
Neuspeed Sport Springs
Nitto 450 225/50
Prime Racing M8 17x7
S15 vs AE86 - 2006 HotWheels Touge
Old 03-22-2002, 11:37 PM
jOYRiDe jOYRiDe is offline
"hes got enough NOS to blow himself up"
Old 03-28-2002, 11:33 PM
Spec-V Spec-V is offline
Send a message via AIM to Spec-V
Actually you're right. The NOS helps the turbo to spool quicker. I would go with Venom or ZEX. I heard NOS was overpriced and overrated.
02 Spec-V Black named Storm because it'll blow ya doors off.
-2 MTX 4000 12"
- MTX 4320 Amp
95 Dodge Neon
-146,000 miles
-Sony head unit
-2 stock speakers in the rear
"Never believe anything you hear and only half of what you see"
Old 04-01-2002, 03:51 AM
Phat804lude Phat804lude is offline
Send a message via AIM to Phat804lude
yes, turbo and nitrous is a possibility. If you get an AEM fuel rail, you can fit bigger injectors in it and it also comes with an extra port that you can install nitrous directly through the rail. You can't run a nitrous dry system with turbo because you inject the nitrous-oxide through the intake with that system, which doesn't work with turbo. Also, I'm not sure if ZEX makes a kit that is a wet kit, and the thing I don't like about ZEX kits is they only spray when the "full throttle indicator" is on. In other words the pedal is to the floor. I'm not sure if there is a way to change that or not. If NOS is over-priced, I would go with VENOM. Venom's system is expensive with the built-in computer management system though. Hope that helps out
Old 04-01-2002, 09:34 PM
The new Venom kit with the computer management has an option to where to can change how the nitrious to shot. You can choose: push button, full throttle, or rpm timed specific. I was looking at that Venom kit and I forgot how much it cost.
-2 MTX 4000 12"
- MTX 4320 Amp
95 Dodge Neon
-146,000 miles
-Sony head unit
Old 04-02-2002, 07:58 PM
90CRXSi 90CRXSi is offline
Send a message via AIM to 90CRXSi
get a SKUNK2 intake manifold and run direct port,get a new ignition, new throttle body(bigger one),get a hondata get alot of gauges(fuel pressure,boost,nitrous,a/f,oil temp,transmisson temp),get a new radiator, cam gears, port and polish,get a new clutch,get colder sprak plugs,valve springs, get bigger injectors,FMU,FPR,new head gasket,fuel pump,
Old 04-05-2002, 09:32 PM
And you will have the fastest whatever you're driving.
-2 MTX 4000 12"
- MTX 4320 Amp
95 Dodge Neon
-146,000 miles
-Sony head unit
Old 04-08-2002, 11:36 AM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
He is right if you want to run both then it is best to get most of that done before even trying it. If you want your car to last. I have a friend out here that was running NOS and a Greddy Turbo with a few mods and he was running 10psi and he did just fine. I don't get it you guys say that NOS is over-priced so get Venom. Venom is one of the most expensive Nitrous kits on the market. Those kits cost as much as a Greddy Turbo. NOS is way cheaper then Venom.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
NOS - Turbo 84 Camaro 355 HELP!! subwoof17 Camaro Discussions 3 11-04-2004 02:17 PM
Can I run Nos?? zboom86 Camaro Discussions 10 05-08-2004 03:04 AM
rsx nos/turbo newrsx Forced Induction 9 03-27-2003 05:10 PM
Can i add turbo and nos in 350Z did anyone do that ??? krissc Nissan 350Z/370Z | Infiniti G35/G37 Coupe 0 12-04-2002 06:36 AM
whats better NOS/turbo?? for a B16A incoming Forced Induction 5 03-20-2002 11:31 PM
