Old 02-21-2005, 11:34 PM
B16Z6+S20's Avatar
B16Z6+S20 B16Z6+S20 is offline
Send a message via MSN to B16Z6+S20 Send a message via Yahoo to B16Z6+S20
Question sunroof problem
my 94 coupe has a problem with the sunroof, it gets stuck when i tilt it open, it looks like the motor is a little worn out cause it feels a little rough, but i took it apart and found nothing, exept a lot of grind plastic in the little pinion that moves the two spiral screws that opens the roof, dont know where it comes from, but i cleaned it and it works a little better, but it still gets stuck half way, it doesnt have any problem sliding, and the ruber around the glass its ok and no rust either. i greased it very well and it work like for 2 days, any sugestion will be most apreciated. thanx
Old 02-21-2005, 11:56 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: sunroof problem
What did you use to grease it with? Was it really dry when you greased it?
You may have already done too much damage to the motor if it was dry when you greased it.
Old 02-22-2005, 12:05 AM
B16Z6+S20's Avatar
Re: sunroof problem
i didnt grease any electrical parts, i used some motul go-kart chain grease on the pinion and those spiral things that the motor rotate to open the roof, after cleaning them with a tooth brush of course. then after installing it i realize i put the tilt sensor wrong and dismounted it again and it was alrready cloged with only one slide open. and yes, it was dry.
Old 02-22-2005, 12:26 AM
whtteg's Avatar
Re: sunroof problem
That wasn't what I was talking about, sorry should have been more specific. I was talking about the slides on each side of the sunroof. If they become dry then it creates an extra load on the motor and gears. And yes it would seem that there should be some sort of grease on the gears too. Try the slides and grease them real good with some multi purpose grease. If that does not fix your problem then you must have a problem with the clutch on the motor or a problem with the slides or clearances.
Old 02-22-2005, 03:57 PM
B16Z6+S20's Avatar
stuck roof
took your advise and lubed the gears and slides, so far so good, and i dont think its clearence problem cause its aligned with the top perfectly and it tilt opens almost half way, but just in case how do i adjust the clutch of the electric motor?
and thanx for the instant suport!
Old 05-01-2005, 04:24 PM
mvftw mvftw is offline
Just got a '95 EX, the moonroof tilts fine, but gets stuck after going back maybe after an 1/2". When you greased yours did you take it apart from the inside?
Old 05-01-2005, 05:42 PM
Making some progress...I found that if I grab the back while it's tilted, it will go back smooth. It seems that after it tilts, it gets cocked and gets stuck, maybe... Or maybe the motor isn't strong enough...
Old 05-01-2005, 11:53 PM
B16Z6+S20's Avatar
Re: sunroof problem
i didnt really fix mine, it seems to be the motor isnt strong enough, couse it only stucks when tilting, not sliding, it opens about a quarter and stops, i took it apart and lube it and it improved a little, but if it gets stuck all i have to do is push it a little and it opens allrigth
Old 05-02-2005, 11:58 AM
That' s what mine does, it tilts fine, but after it tilts it only goes back 1/2" and stops. I agree that it seems to be a motor problem, but not sure. Hopefully others will chime in...
