Computer Reset?
I have a 98 GTP and I need to reset the computer.
I have unhooked the battery for hours and it doesn't seem to work. Is there any trick to resetting the computer on these cars? Either that or I have more problems than I think. Thanks Ed |
Re: Computer Reset?
Unhooking the neg terminal on the battery for 1/2 hr should do the trick. What exactly are you hoping goes away?????
Re: Re: Computer Reset?
The fastest way I know to get it reset, is take it to the dealer for a tune up. Works everytime.
![]() Quote:
Re: Computer Reset?
Then turn the key to the off position. Now re-connect the battery positive cable. Now start the engine and the SES light should be off. This procedure resets the SES light and clears all ECM/PCM DTC codes. However, if you have a bonifide ECM/PCM problem, the error is likely to return after 1 to 3 drive cycles or sooner. You will need to reset your clock, etc afterwards. Another option to to buy an ODB-II Code Reader which will have a reset button to clear DTCs and SES light. Comes in handy when you want to verify DTC codes, save money and do your own work on the car, especially if it is out of warranty. Good luck! 2001 Buick Regal GS/1999 Regal LS |
Actually I put a Short ram intake on it and I ruined the screen when I did. The car ran fine for about 4 days I think, this is my wife's car so she was driving, then it started hesitating and missfiring at WOT. I have since replaced the screen and it was still doing it wanted to reset the computer before I started to troubleshoot the ignition.
Thanks Ed |
Re: Computer Reset?
You sure you didn't suck anything in when this happened?
![]() Quote:
Don't think so throttle body is clean and the MAF is working fine.
Re: Computer Reset?
If it's misfireing it has to bring up some numbers. Scan it and see what you come up with.
Re: Re: Re: Computer Reset?
Damn, I hate those. Could be just about anything. Plugs, wires, I had a wire go bad that runs over the top of the rad. Took five days and a lot of luck.
Check wires, and all the "dumb" stuff. If you can find it, I'll email you where the wire was that I found. You would think they'd come with a computer that says "it's #1 plug wire". Good luck. Quote:
Re: Computer Reset?
During hard acceleration (WOT), the ECM/PCM operates in open loop mode and the MAF sensor input is critical. The new induction system allows alot more air to flow and you may get additional air turbulence, etc. I had a similar problem with my son's '97 GTP when we installed a Thrasher CAI last year. It missed at WOT or any hard acceleration. No SES light or DTC codes after a scan. We cured the problem by replacing the stock MAF with a Granatelli Racing MAF sensor with cold air tuning capability. Hasn't missed a beat since. 2001 Buick Regal GS/1999 Buick Regal LS and ----> 1997 Pontiac GrandPrix GTP - Thrasher 3.4 SC pulley, Trasher CAI, u bend delete, hi-flow CAT, Granatelli MAF, ASE Performance Chip. ET:14.3 @ 96mph |
Sorry if I'm a little OT here but I have to ask.
I have to replace a MAF sensor. Would there be much difference between a stock MAF or a Granatelli Racing MAF sensor on a stock 99GT? Also, ether or, do I have to reset the computer? |
Re: Computer Reset?
We needed one out of necessity because of the Thrasher CAI mod and the lean condition at WOT on our '97 GTP. web site: www.granatellimotorsports.com It is highly recommended to reset your ECM/PCM computer after this type of modification but not mandatory. Good luck! |
Re: Computer Reset?
Thanx bnaylor3400.
Re: Computer Reset?
