Old 02-21-2005, 09:07 PM
kingpinn's Avatar
kingpinn kingpinn is offline
how quick would this setup be or quess
what do you think a stock d16a6 stock crxsi 91 with 8psi from a good turbo setup will run in the 1/4mile yes i know there are alot factors to add in but just quess do you thiink its go for high 14's or what just tell me what you think
Old 02-21-2005, 09:10 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: how quick would this setup be or quess
low 15s high 14s? depends on lots of things, but mostly the condition of the engine
not sure but is it safe to run 8 psi on a stock engine?
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-21-2005, 09:14 PM
kingpinn's Avatar
that i dont know but we will leave it there since it already there
Old 02-21-2005, 09:34 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Between 5-8 psi on a good running A6 should be fine. Also what size turbo you talking about? 8 psi out of a T25 and 8psi out of a T4 are a really big difference.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 02-21-2005, 10:00 PM
kingpinn's Avatar
well let say a t4
icE_x's Avatar
^ true forgot about that - size DOES matter lol
Old 02-21-2005, 11:54 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
high 14s
Team Lonely Drivers
Old 02-22-2005, 08:28 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
Re: Re: how quick would this setup be or quess
Originally Posted by kingpinn
well let say a t4
t4's are huge for our cars arent they?
youll probably also have quite a bit of lag to boost
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
Old 02-22-2005, 08:53 PM
kingpinn's Avatar
then what is the best turbo for our cars ?
Old 02-22-2005, 09:05 PM
i think the ihi rhb5 (might be a little off but close) is a small turbo good for a first project spools quick and is set somewhere around 5psi can be found on some ford cars like probes i think. the t3 is also good smaller than t4 alot more practical. most turbos you can find in a junkyard that came stock on a car work pretty well.
89 std hatch back
D15B1 4 speed
MPFI Swap
Old 02-22-2005, 09:08 PM
icE_x's Avatar
depends on what your objective is, jus plain ol speed?
Old 02-22-2005, 09:22 PM
Yeah if you want something that spools quick and has a nice punch I would go with a T25 or T28.
Old 02-23-2005, 08:23 PM
kingpinn's Avatar
yes just speed.... but needs to handle putting out 15psi in a while when the time comes.....
thanks
Old 02-23-2005, 10:31 PM
I would go with a T28. Spools quick and can push 15-18psi if I remember correctly.
Old 02-24-2005, 08:02 AM
91civicDXdude's Avatar
I ran 10psi every day for over 6 months on my stock block Y7/Z6 minime with no problems. it hauled ass.
An engines ability to handle boost is not limited by psi, but rather power output capability (can the rods/pistons/etc. physically take the power outputted by X amount of psi), and fuel and spark management. You can easily blow an engine with 5psi with imporper management, and can also as easily run 10-12psi on astock d series with proper management, although i wouldn't recommend more than 10psi daily.
As was said, your time all depends on your drag racing skills, tuning, weight of the car, track conditions, etc.
If you had slicks, and ran a *perfect* run (1.9 60', perfect shifting, perfect conditions), you could possibly run a 13.9 or so, but if i was to guess, i'd say you should expect mid 14s.
