Old 02-21-2005, 08:25 PM
graber graber is offline
front axle
with enought work to do on the farm. my nagging wifes blazer front axle is trying to engauge in to wheel drive. told her to drive it in 4 wheel drive until i could work on it but just started world war 3. any help with blazer???? by the way it's a 98 chevy s-10 blazer Lt with elect. shift.
Old 02-21-2005, 09:56 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: front axle
check the vaccume accuator, its under the battery i beleve
Old 02-21-2005, 09:59 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: front axle
How do you know it is trying to engage 4x4?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-21-2005, 10:06 PM
Re: front axle
now that i re read the post, is it in 4 wheel or is it trying to get there and if its only trying like blazer said how do you know that its trying to go in?
Old 02-22-2005, 01:57 PM
Cam1959 Cam1959 is offline
i not familiar with electric shift. i have manual levers and vacuum switch/lines. but sounds like cable to front diff from vacuum diaphram is sticking bit and not all way back in diff. when ingaged vacuum diafram pulls in pulling cable. for quick fix i guess disconnect locking clip at diafram that goes thru cable end connection to diafram shaft. later check that diafram is coming all way out when off and cable moving back too. is sticking my guess is where cable enters diff where there is removable housing covering thick cable shaft/oil seal ... try lubing that and be sure to use rtv self-curing gasket selant there between hopusing and diff.
Old 02-22-2005, 08:16 PM
Re: Re: front axle
the front axle is clicking & you can put it in 4 wheel and it will quiet.
Old 02-22-2005, 08:22 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: front axle
That doesn't mean the 4x4 was trying to engage.
That means you have some play in that tire's driveline and when you put it in 4x4 the play is removed.
Old 02-22-2005, 08:28 PM
Re: front axle
what kind of play
Old 02-22-2005, 08:31 PM
BlazerLT's Avatar
AF -Advisor
Re: front axle
What side was this clickng coming from?
Old 02-22-2005, 08:32 PM
Re: front axle
the clicking noise sound's just like the early GM automatic hubs did when they would get dirty.
Re: front axle
right side
Old 02-22-2005, 08:58 PM
BlazerLT's Avatar
AF -Advisor
Re: front axle
CV joint has a torn boot probably allowing sand in.
CV joint could be toast.
Check it out.
Old 02-22-2005, 09:14 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Re: front axle
Check it out.
A tall tale sign is clicking so I would agree with you on this one.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
