Help!!! Reverse Light Problems
I have a 1995 SLP Firehawk 6-spd which has devloped the problem of blowing the fuse every time I place it in reverse. Any ideas.
Re: Help!!! Reverse Light Problems
Re: Re: Help!!! Reverse Light Problems
Bad bulb probably change the bulbs for the reverse lights and check the wiring if that doesnt help
I checked the bulbs which were fine and can't find a short anywhere.
check your reverse light switch on your shifter to make sure it hasn't gone bad. other than that you have to have a dead short or ground dead in the circuit. if your switch is good then use a multimeter to check the ohms on the wires. to check your switch just use a jumper across the terminals to see if it will blow a fuse the the switch out. good luck
The switch was shorted. Thanks for the advice and ideas to diagnose the problem.
