Old 02-21-2005, 07:54 PM
typerx7 typerx7 is offline
mini me sohc vtec....d-series 4 life!
ok guys next one up to set down.....i want to do either an all out swap or a mini me swap....i know all the specs on full swaps...wat to get....i just want to spend under a grand to get some power.....ok lets jsut do a mini me vtec...from a 96? ex sohc? help me find one and help me get it in...
Old 02-22-2005, 08:34 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
I'm guessing you have a 94 DX/LX (D15B7) since you are looking into the Mini-me swap. Since you have a 94 civic, use a D16Z6 head. Also use the ecu for the D16Z6. If you have an auto tranny, use an auto ecu, manual use a manual ecu. The D16Z6 is found on the 92-95 civic EX, the 92-95 civic Si Hatchback, and I think the Del Sol Si also.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 02-22-2005, 09:34 PM
Re: mini me sohc vtec....d-series 4 life!
thats right, d15b7 with manual tranny....so i should get a d16z6 from a 92-95 civic? ex right....how much u think that would cost and level of difficulty to put it in?
Old 02-24-2005, 03:56 PM
mtbmaniac mtbmaniac is offline
d16z6 swap
Last year I did the d16z6 swap with my 92 civic Dx, The swap was very easy tecnically speaking, make sure that you get the right wiring harness for the motor, although the only thing that was diffrent was the connector for the vtec, solenoid. I actually just made a plug my self and wired that into the plug from the ECU inside the engine compartment. U may want to invest in a bigger radiator for the car, because i sometimes have trouble with the temp creeping up a little when going down the freeway in summer(I may just need a new radiator in general, I used the one that originally came with the car). Other than that the swap went really well, and the motor is still runnin great.
Old 02-24-2005, 06:23 PM
well thnx a bunch for that reply....its always good getting reassuring replies when this is my only car, and the onyl car i can afford...the only thing that may bother me is the whole process: unbolting i can handle, but reassembly may be tricky for me, not sure why but i have my doubts....also, is there anything about the ditrsibutor i need to change or replace? or is that only when i would do a swap form a 96-00 vtec engine? also, how hard is it to reset your timing, or maybe even advance it...i was thinking of adding an adjustable cam gear while i was at it...im not worrying about the wiring, thats one thing im good at....any other tips can help guys i always liek to think big things through before i go about doing them, especially on my car.
Old 02-24-2005, 07:13 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: d16z6 swap
Sounds like you had some kind of cooling problem. There's no need to swap out a stock radiator for a d16z6, the stock one will work just fine.
Typerx7 - Here's a walkthrough for a mini-me: http://www.iapecc.com/mini_me.htm
Old 02-24-2005, 10:25 PM
if i need an hx engine timing belt, what do i say when i go to parts store to get it? what year i mean, should i just say 95 ex vtec 1.6 liter? or....im not sure....and how do i get the timing belt off..an easy way of putting it.
Old 02-24-2005, 11:35 PM
CivicSpoon's Avatar
There is no Spoon
You should get a service manual for your car (preferably a Helms). This is the best thing anyone car buy for their car.
Old 02-25-2005, 11:35 AM
distributor
Definately get a service manual I used a Haynes, but any kind should do. You will need the distributor for the d16z6 engine because the distributor from your old engine will not line up with the new bolt holes on your new engine(it does look quite similar though). we found this out after we had the motor already in and went to put on the distributor and it wouldnt fit. Had a couple days wait to get the new one. Find someone with a timing light because this makes normal timing or advancing the timing very easy.
Old 03-02-2005, 08:33 PM
i have a manual
Old 03-26-2005, 06:27 PM
HiRev'n HiRev'n is offline
Send a message via AIM to HiRev'n
does anybody know how much power that would give out if i did that mini me swap.
Old 03-27-2005, 12:01 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Alright, HT's last two issues (march/april) had "wrenchin'" articles focusing on a mini-me swap in an LX. They used the Z6 head also. They went from 91 to 121 hp and 89 to 91 ft-lbs. They also had a chart with compression for different combinations.
Cylinder Head | Cylinder Block | Compression |
| . Z6 . | . Z6 . | 9.13 : 1 |
| . Z6 . | . Y8 . | 9.29 : 1 |
| . Z6 . | . A6 . | 9.95 : 1 |
| . Z6 . | . ZC . | 12.03 : 1 |
| . Z6 . | . D15 . | 10.10 : 1 |
| . Z6 . | . Y7 . | 9.62 : 1 |
| . Y8 . | . Z6 . | 9.45 : 1 |
| . Y8 . | . Y8 . | 9.61 : 1 |
| . Y8 . | . A6 . | 10.33 : 1 |
| . Y8 . | . ZC . | 12.61 : 1 |
| . Y8 . | . D15 . | 10.52 : 1 |
| . Y8 . | . Y7 . | 9.96 : 1 |
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
