Old 02-21-2005, 08:36 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
4G63 p.s.i
I have a N/T 2.0L DOHC 4G63 Engine on my 91 Eclipse GS and I was wondering if I were to turbo it what p.s.i. could it handle with stock internals.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 02-21-2005, 08:41 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: 4G63 p.s.i
my buddy put turbo cams in his and he is boosting 18 right now. i'm not sure what other diffrences there are besides the cams.
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 02-21-2005, 08:52 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 4G63 p.s.i
the pistons are different too. NT use high compression pistons and the turbos use low compression. 18 psi is much more then i would run on a stock NT block. i would recomend about 9 since thats the lowest the 14b wastegate lets you boost. there is lots of other stuff that needs changed to turbo a NT too.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-21-2005, 08:54 PM
Re: 4G63 p.s.i
that's why it's not mine lol he has had this thing turbo for over a year now lol he has a big 16g also not the 14b
2002 VW Jetta 1.8T
Old 02-22-2005, 12:02 AM
Re: 4G63 p.s.i
here is every thing you will have to do http://www.dsmtuners.com/forums/showthread.php?t=48231 i got this from VFAQ
2002 VW Jetta 1.8T
Old 02-22-2005, 05:48 PM
Re: 4G63 p.s.i
thanks its greatly appreciated
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 02-22-2005, 09:32 PM
Re: 4G63 p.s.i
If I through some aftermarket pistons, rings, cam and all the good internal shit about how many lbs of boost could I put on it without screwing all the internals up.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 02-22-2005, 10:02 PM
Re: 4G63 p.s.i
if you do pistons, rods, rings, etc then you can basicly boost as much as you can supply fuel for. granted if you screw up at all boost that much you will break shit but thats what happens
-1stGenRocks-
Old 02-22-2005, 10:05 PM
Re: 4G63 p.s.i
Yeah I wouldnt Boost alot I just want it to go faster then it is right now. Thanks though
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
