Old 02-21-2005, 07:28 PM
BLAZERING BLAZERING is offline
Explosions thru the exhaust pipe,Help!
92 Blazer s-10 4.3 l
After changing distributor cap and rotor and driver side knock sensor(engine started to miss and die while turning or stoping) ,i started to get very loud explosions thru the exhaust pipe,even thought it idles much better,also i noticed a reduccion in power while driving.Any of the Gurus here has any opinion?
Thanks
PD the explosions happens while i get my foot off the pedal ,as soon as i accelerate they will go away.
Old 02-21-2005, 07:37 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: Explosions thru the exhaust pipe,Help!
did it start as soon as you changed cap and rotor? if so check over your work make sure correct firing order, and that both cap and rotor are setted properly.
Old 02-21-2005, 08:01 PM
Thanks
I rechecked the firing order on the manual ,the cap and rotor are seated properly and yes it started just after replacing the cap and rotor.
Will the engine even start with the spark plug cables connected wrong?
The idle seems fine...
Old 02-21-2005, 09:49 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Re: Explosions thru the exhaust pipe,Help!
if it started with the wrong fireing order, your replacing the lifters... you would know that by now... only thing that comes to mind right now is a sticky exhaust valve, or something along those lines
Old 02-21-2005, 09:54 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
The firing order is out for sure.
Do you have the TBI or CPI 4.3L?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-21-2005, 09:59 PM
Re: Re: Re: Explosions thru the exhaust pipe,Help!
i gave up on it ,it is resting in to the local mech shop
Old 02-21-2005, 10:00 PM
BlazerLT's Avatar
AF -Advisor
Wow, you give up fast don't you.
Old 02-21-2005, 10:08 PM
what do you mean quick its been like 3 hours seince he posted the question, its obveously a huge problem
It is the CPI 4.3 L, isn`t the firing order 2,4,6 passanger side,1,3,5 driver side ,clockwise?
Old 02-21-2005, 10:20 PM
BlazerLT's Avatar
AF -Advisor
Do you have the round distributor or the horizontal one where the plug wires plug in from the side?
Old 02-21-2005, 10:21 PM
It has been 3 days of messing with it ,besides i got a job to go to ,anyways i`ll post the solution as soon as i find out
Old 02-21-2005, 10:30 PM
The round one
Old 02-21-2005, 10:39 PM
BlazerLT's Avatar
AF -Advisor
Old 02-21-2005, 11:06 PM
Angry Re: Re: Explosions thru the exhaust pipe,Help!
according to the haynes manual the firing order on the 87 and later (mine`s 92) is different,i`m probably screwed up,will the error cause additional problems ,like valves broken or other nightmares?
Old 02-21-2005, 11:08 PM
more then likely
