Old 02-21-2005, 06:59 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
Question How to lift it
i am buying a 2" lift with shackle and spacer. Can someone email my directions on how to do this the correct way.
Old 02-21-2005, 10:11 PM
gtmud gtmud is offline
Re: How to lift it
Scuba,
I have a 2" lift(coil spacer, add-a-leaf) would recommend a 3" lift, you'll be happier.
Old 02-23-2005, 01:32 PM
92XJDEVIL 92XJDEVIL is offline
Re: How to lift it
What year is your xj? I have a 92 and it is lifted with the spacer shackle method. I believe I still have the instructions somewhere. One thing to please, please remember is that the upper bolt for the rear shackle is welded on the inside of the psuedo frame rail. If the weld breaks on that nut, there is some work involved to repair it. Main thing, take your time and go slow.
Old 02-23-2005, 06:21 PM
scuba4321's Avatar
Mine is a 1993, did you have any driveability issues?
Old 02-24-2005, 07:35 AM
Re: How to lift it
After even a 2" LIFT YOU WILL NEED AN ALIGNMENT! That should be the only thing you should notice.
Old 02-24-2005, 12:12 PM
mx52nv's Avatar
mx52nv mx52nv is offline
Re: How to lift it
hey Scuba, I have a pair of stock ZJ coils you may want. they will give you 1in lift over stock and combine them with the spacers to give you more. they also flex better than the XJ coils.
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 02-25-2005, 08:49 AM
Re: How to lift it
Scuba, to be honest, the ride has actually improved believe it or not. I am very pleased with the outcome. I need to trim the exhaust. the bottom bolt on the shackle hits the exhaust tip. Other than that all is well.
Old 02-25-2005, 05:12 PM
scuba4321's Avatar
devil,was it hard to do? what size tires do you have
Old 03-01-2005, 10:23 AM
Re: How to lift it
No, it was not hard at all. The hardest thing for me was taking my time on the rear. It helps a lot to have some help with you, more muscle than brains as far as the help goes. Just being careful and not rushing you can make it through pretty easy. I could not find my instructions, but i know they are posted on the net somewhere, once I find them, I'll post the link for you. Right now, I have 31 x 10.50 on stock 95 Wrangler rims. Given the mountain like terrain in Houston, Tx (lol) they wor fine.
Old 03-02-2005, 03:48 PM
scuba4321's Avatar
Just ordered my lift today,will be here friday, Already got my pro-comp 31's in my garage on Jeep Classic wheels, can not wait!
Old 03-03-2005, 01:57 PM
thinmints thinmints is offline
Re: Re: How to lift it
With the bigger tires do you have any issues with the speedo being out of wack?
Old 03-04-2005, 10:36 AM
Re: How to lift it
thinmints,
yes, any time you change tires/gears it is good to have your speedo calibrated. When I finished with the lift etc, I had to change the gear in the tranny. I used this article as a guide and it was easy
http://www.jeepin.com/features/speedogear/index.asp
