Old 02-21-2005, 06:04 PM
mitch505 mitch505 is offline
97 LeSabre Electrical Problem
Car lost electrical power on highway doing 55 mph. The clock reset to 1:00 but the radio stations held. Pulled off to the shoulder and was able to restart just by turning the key. The car sometimes doesn't start from park also. The battery and alternator check out ok. Any ideas?
Old 03-01-2005, 07:42 PM
liv2ride liv2ride is offline
have you tried replacing the O2 sensor? i had that problem once and after replacing the O2 sensor it ran great!
Old 03-05-2005, 09:18 AM
auto trainy auto trainy is offline
Re: 97 LeSabre Electrical Problem
And make sure it has a good tight connection.
Old 03-24-2005, 05:57 PM
formzy formzy is offline
Possible crankshaft position switch
Have a '97 lesabre and car would just die especially at higher speeds. Didn't set check engine light, but pulled history codes with scan tool. Found crankshaft position circuit problem. Replaced this switch and has been fine now for four months.
Old 03-25-2005, 12:50 AM
s426 s426 is offline
hi
i had same problem,on high way the car lost power almost shuts off, then the light came back on insturment panel, at first i thought is pcm<computer> because i hear a click noise in ash board passender side ,
i also suspect default fuel pump,
i checked the release valve for gas pressure, it was ok.
then one day i coudent start the car because was no power,
i took off the both cables off the battrey, the <-> ws clean , but the <+> was realy bad corrosion, i discover that after i took off the red sleve<jacket> for <+> terminal,,
i cleand it no problem since.
check the postive terminal by removing the red cover and clean inside the two copper terminals,
see what you been doing is testing the batt before terminals so it reads ok, and when you start the car the alt give out the correct reading , but when you on high waythe car need more power could not get it from bad terminal,beside loss connection because the terminal not having good connection due to corrosion
good luck
