Old 02-21-2005, 04:16 PM
Gsir8 Gsir8 is offline
Send a message via AIM to Gsir8
Where can I get info on my transmission?
In my 1972 el camino, it was originally a 3 speed on the steering column, but someone added a new transmission with the shifter on the floor. I know nothing about this transmission only that it is a GM transmission. IS there somewhere I can enter the numbers to get info on it? Or if someone knows alot about GM transmissions I'd give you the numbers.
Old 02-22-2005, 08:31 AM
MrPbody MrPbody is offline
AF -Advisor
Re: Where can I get info on my transmission?
Still have three forward gears? If so, is there a side cover? Or a top cover? Or is it a 4-speed? Iron case or aluminum? More detail, please.
Old 02-23-2005, 08:07 PM
I didn't have too much info, but its finally out of the car and I'll be able to get some more info. I didnt look to closely yet, but I will tomorow Its a 4 speed with side cover, and iron case I believe.
Old 02-24-2005, 08:25 AM
AF -Advisor
4-speed, iron case (and tail housing) is a Saginaw. Iron case with an aluminum tail would be the Borg Warner "Super" T-10. The Saginaw is woeful. Won't take any serious power without falling out. The Borg Warnre, on the other hand, is among the best manuals of the era. Muncie (all aluminum, 7 bolts in the side cover) is considered the best one of the era.
Old 02-24-2005, 08:00 PM
I was wrong, it is aluminum, and is a muncie. I just don't know wether is m20, m21, or m22. I'm pretty sure its not an m22
