Old 02-21-2005, 04:57 PM
t-ribbit t-ribbit is offline
ecu code 4
i have a b16 in my crx and i cant rev it passed 3... it is like the rev limiter is set at that point... i used a different ecu but the same thing happens.... my ecu flashes 4 times .... i was told it was the crank angle sensor code.... how hard is it to fix.... has anyone had this happen to them???
Old 02-21-2005, 05:01 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: ecu code 4
Crank angle sensor is in the distributor, and I believe it will stop you from reving past 3k too. Might want to try a different distributor and see if that fixes it.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 02-22-2005, 03:21 AM
Hybrid1990crx's Avatar
Re: ecu code 4
yeah its in the dizzy, you might have to replace it all together.
Old 04-30-2008, 01:41 PM
timintegra timintegra is offline
Re: ecu code 4
i have a 91 teg throwing code 4 changed the dizzy, ecu same problem. need help bad
Old 05-07-2008, 06:49 PM
Re: ecu code 4
check your wiring.
