idle misfire, scope says its random
My 1996 Jimmy is awful in traffic. It has new Delco wires, Champion platnum plugs, Mobil 1, distrubutor cap and rotor, recent pro fuel injection cleaning, and lots of opinions as to what is going on (fuel pump, sensors, injectors, air leak, etc.). It is flooding, everyone agrees and it has cooked the converter. Cold starts are immediate, hot starts tough. Highway performance is fine, fuel economy primarily highway averages 18 mpg.
The most recent visit to a shop came up with I think it has to be in the intake, but the random misfire indicates something other than the "spider". Could I get some experienced advice? |
Re: idle misfire, scope says its random
You don't have a spider, they were killed in 1995.
Have your fuel pressure checked with the key on and the engine off. It should be between 61-66psi.
1995 Factory Blazer Service Manual for sale, PM if interested. |
I will have the fuel pressure checked today. If it is unacceptably low, is the fuel pump normally the culprit (after fuel filter)? |
Thanks for the advice. Judging by this site, fuel pressure is the most common problem on these vehicles.
Sounds like the fuel trickles instead of spraying at idle due to low pressure due to possibly low voltage, obstruction or failing fuel pump, right? New fuel pump has been recommended by 2 shops, but I thought that either it worked or it did not work... |
Did you find out the pressure yet?
Re: Re: idle misfire, scope says its random
The garage guy still says it has a spyder, which makes me a little leary based on what you said. The forum seems to indicate there are a lot of wiring problems repaired at garages by replacing expensive pumps and things, so I want to get in on fixing it right, as economically as feasible. |
a lot of jimmy's seem to get moisture in the distributor cap. take it off and blow it out with compressed air. if that doesn't fix it try removing the egr valve and cleaning it, they seem to get gummed up and stick a little bit. i don't know what shops you have been going to but a gm dealer has access to lots of information and a lot more experience with your vehicle than independent shops
Re: Re: Re: idle misfire, scope says its random
You will have to remove a cap like on your tire valve stem to get access to the screw fitting.
1995 Factory Blazer Service Manual for sale, PM if interested. Last edited by BlazerLT; 02-26-2005 at 01:01 AM. |
Re: Re: Re: Re: idle misfire, scope says its random
I was also considering hotter heat copper plugs in place of the champion platinums that have 5000 miles on them. |
1.) Have you ever changed the fuel filter?
2.) Get the fuel pressure checked with a fuel pressure gauge. 3.) Suggest going to AC Delco Platinum plugs gapped properly. DO NOT START INSTALLING HOTTER PLUGS.
I will buy some Delco plugs to replace the Champions. |
did you check the fuel pressure yet.
multiple random misfire - code # ???
Cracked distributor cap OR cracked COIL. Check for arcing. It took me quite a while to find the cracked coil as the problem was intermittent, only happening when damp outside.
Re: multiple random misfire - code # ???
If fire is good, the engine should not miss. If coil is good, everything else is new AC DELCO, so either the computer is confused or it is a fuel injection issue, right? I have been trying in vain to have a garage test fuel pressure. I am just going to have to buy my own dadgum gauge and do it myself. If it is fuel - either too much or not properly sprayed, that might result in idle misfire... |
