HELP ANYBODY bmw 1998 525 tds Misfire
HELP, I have a low miles 67k which has a slight miss at low speed, noticable when changing up from 1-2nd at low speed, the engine will actualy cut out for a split second, a main agent had no diagnostics on the computer and didn't help an ex bm mec tels me an error code 01 is saying FUEL QUANTITY ADJUSTER MEC/ELECTRICAL FAILURE and says fuel pump is us £700 + fitting, can anyone advise? is this true! or can there be another explanation for this, also looking through some of the history a non main agent fitted a fuel filter? could this cause this problem? as his dodgy brake pads broke up and scored the discs?????
Re: 1998 525 tds fuel pump?
Fuel pumps on these models do give problems. I have had two replaced on my 525d. Cost here in Portugal last year was about €300 from a main dealer. I also had problems under warranty with the 2 fuel sensors in the tank. Usually you get the DDE light illuminated with fuel supply problems
hello all, i have a 1998 525 td se . when the car is standing the engine will sometimes drop in revs' almost stall. is this the fuel pump? my cars done just over 100 000 miles.
Also is it common for the car to smoke alot when pressing the accelerator harder? leaving a smell? can this be the fuel pump alos? pls advice!! |
Re: Re: 1998 525 tds fuel pump?
did u get your problem sorted mate. it seems like i have the same problem??
mercedes 190e petrol engines used to get the problem of stalling
i owned one and its was something of "blower". i forgot the exact term used it could be electronic components also would be better if you could check if the pump sending the right amount of fuel pressure before replacing |
