Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-21-2005, 01:39 PM
Highway Drfter Highway Drfter is offline
Several Problems - any help?
Hello friends,
I just purchased a 93' GM and it has a few bugs. Hopefully someone can point me in the right direction.
I can't get the headlights to work. While driving the vehicle home I switched on the lights. The taillights flickered w/ nothing up front.
The fuses look good. The parking lights/brake/turn/rear/and highbeams all work. Any "weak" spots that may have burned out?
In addition, the air bag light on the dask flickers on about every 3-5 seconds. This is'nt a prob. until I get in a wreck or it blows unexpectedly.
Should I be worried?
Thanks for all help!!!
Old 02-22-2005, 04:52 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
does your horn work at all?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 02-23-2005, 09:51 AM
Yea, The horn works.
Everything in the stering wheel works, horn, cruse cont., etc.
Old 02-25-2005, 09:05 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Several Problems - any help?
Might just be a bad headlight switch. Any other odd problems with the electronics?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-25-2005, 09:06 AM
Also, try jiggling the headlight switch to see if the lights come on and off....
Old 02-25-2005, 09:41 AM
I've tried the headlight switch "wiggle" with no results.
The only other electrical prob. is when I start using alot of options,
air radio, lights, wipers etc. The lights on the radio will flicker and dim at times.
Is there any way to check the headlight switch without taking the dash apart?
Thanks for your help!
Old 02-25-2005, 09:45 AM
I'm not sure about the switch for that year and the dash, without taking a look at it.
Your issue with the heavy electrical load rings a bell though. I had problem once, the positive battery cable was somewhat corroded, and caused several odd problems until the car died one day. Check your positive cable; even if it looks good on the outside it could be nasty inside. Easy fix and inexpensive.
Old 02-25-2005, 11:37 AM
I'll give it a look Thanks!
