Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-21-2005, 01:08 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
idle
ok so for some reason my idle went from normal(750ish) to a little low(650ish) and is kind of rough now, it still runs fine, its just kind of annoying and I'm not sure what caused it cause it was fine for awhile... any ideas? maybe its the timing?
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 02-21-2005, 09:40 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Lets see...
1. Possible Cas moved (timing)
2. Bad spark plug
3. Clogged air filter?
4. Thermowax/idle stop problem
5. Initial idle setting problem
6. ECU problem..
7. Waterthermosensor problem...
Guess what I am getting at is... Could be alot of things.
Did you scan for codes?
1988 10th AE Edition TII
More mods then you have.
Old 02-21-2005, 10:47 PM
Soyo's Avatar
Re: idle
I checked the air filter and it seems fine, but no I haven't checked codes... could it possibly be the gas? it was tuned with 91 octane and last time I filled up I'm not sure if I put in 91 or not, I think I may have put in 87 out of habbit, also it was a tiny place I'd never heard of so I doubt it was very good gas to begin with...
I put in half a tank of 91 today though so hopefully it gets better and that will be the end of it lol
Old 02-22-2005, 06:58 PM
fcdriver fcdriver is offline
Re: idle
Now don't quote me on this but I don't think 87 octane would cause it to idle rough just cause a slight bit of spark knock under high boost.
I would check the plugs first and go from that.
Originally Posted by dampachi
Violence isn't always the answer..but sometimes..depending on the question..it can be the answer.
