Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 02-21-2005, 01:08 PM
melsa1 melsa1 is offline
2000 Elantra code p0455
Hai,
I need some help with this 00 elantra i have a code p0455.
purge control solenoid valve or
canister close vv is stuck open code p0455 is displayed.
Where are these valves located and what is the test procedure.
Thanks in advance.
Old 02-22-2005, 09:49 AM
Wa jang chang Wa jang chang is offline
Re: 2000 Elantra code p0455
I am no expert on this... however, I did a little search on this forum and discovered the fact that most P0455 CEL were set by loose gas cap. You may want to re-tighten the gas cap and disconnect the battery for few minutes for the computer to reset the CEL. Good luck!
Old 03-20-2005, 06:03 PM
speedy03 speedy03 is offline
how do i reset my check engine light on my 2000 elantra w/o taking it to a dealer or auto parts store?
Old 03-28-2005, 05:17 AM
sirsmiley sirsmiley is offline
try disconnecting your battery for about 10-15 minutes until the computer forgets everything, if this doesnt work, go to an autozone/pepboys/etc and they will reset it for free
if its a loose gas cap it usually goes away within a day or 2 once it is fixed , regardless of resetting the code
