No night driving for me...
when it rains, it pours. I just hopped in my '98 jeep cherokee sport this morning and pulled my headlight knob right out of the switch! I'm wondering if i need a new switch or can fix the one i've got, but first I was looking for maybe a how-to website so I could get pics of how to pull my dash apart without busting the plastic all to hell. PLease me out with this, thanks
Re: No night driving for me...
WHEN YOU SAY THE PULLED OUT YOU CAN TRY PUTTHE STEM AND KNOB ASSEMBLY BACK INTO SWITCH YOU MAY HAVE TO TURN IT TO GET TO SLIP BACK IN PLACE. IF IT GOES ,PUSH IT ALL THE WAY IN. THEN TRY PULLING IT BACK OUT. IT SHOULD GO BACK IN AND LOCK IN PLACE. IF IT GOES IN RIGHT YOU CAN FEEL IF THE SWITCH WORKS AS YOU PULL KNOB BACK OUT. QUESTIONS HOLLER DALE [email protected] |
If you do end up having to remove the dash. Just be aware that it is a bit involved. First you have to remove all of the coverings with just a screwdriver (you may need a jointed scredriver for the windshield defroster cover). Then to get the instrument panel off you will need to remover two large bolts on the bottom of the dash on either side of it, and loosen two more near the steering column. If at all possible I would advise trying to remove the dash just enough to get to the lights switch. If that proves impossible...mark where each plug goes in the dash so that you remember where to replace them in reinstallation. If it were mine I would try everything I could before starting on the dash.
Women are in no circumstance a good replacement for a JEEP. |
The good news is that its really easy to replace this switch if you need to, and cheap too. Bad news is its a pain in the arse to remove the dash covering..
Pick up one of the Hanes manuals. It has pics and how to's for doing this type of stuff, even rebuilding your engine if need be. |
Re: Re: No night driving for me...
With the knob off you need a socket with two prongs on it, kinda like for the nuts behind radio knobs. You might be able to grind one or use thin long noses. I just looked at mine, a 97 Sport, and I can probably get to it without taking the dash off, if you reach in from below by the pedals. |
