Old 02-21-2005, 12:29 PM
DigitalSpuder DigitalSpuder is offline
Who can answer this for me??? (SUBS)
OK...here is my question...
Why does my single JL 12w6v2 sound a lot better in my bandpass box by itself at 2 ohms being run by a JL 500/1 amp, compared to the two subs hooked up in series/parallel at 4 ohms witht the same amp.
I can get the subs to1 ohm, but that was making them bottom out.
WHAT DO I DO???
It seems akward to have just one sub pounding when I have two available. I don't want to get a new amp that can support 1 ohm stability because I love the silver savage (JL 500/1).
HELPPPPPPPPPPPPPPPPPP
Old 02-21-2005, 12:59 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Who can answer this for me??? (SUBS)
cuz its a bandpass box...... build a new box!
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-21-2005, 01:02 PM
i hear you, i just hate the idea of having to buy a box. You said you were able to build one right? How much would that run me
Old 02-21-2005, 01:09 PM
t25342003 t25342003 is offline
Send a message via MSN to t25342003
Re: Re: Who can answer this for me??? (SUBS)
Well if you want to build your own box it all depends on how much wood you will need. and it also depends on how much money you want to spend on the plywood or particle board which ever you want.
But i ust built a box and spent about 60 on a sheet of particle board. but it runs from 30 to 100 dollars a sheet.
Old 02-21-2005, 01:12 PM
ok i have a question.
I have 2 audiobahn 12's 1100 watt rms and i have a 400 watt walmart brand amp hooked up until i can find another one. well i found another one and the walmart brand hits harder than the kicker amp I got.
Help....
Old 02-21-2005, 02:52 PM
60 a sheet for particle board hmmmmm u got RIPPED... 25 bux sheet for 3/4 MDF. About ur flame q's.... how are they wired what is the wal-mart amp and what is the kicker amp?
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-22-2005, 09:59 AM
Thanks all...
Old 02-22-2005, 11:25 AM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Re: Re: Who can answer this for me??? (SUBS)
yeah...moron...
DO NOT use particle board OR plywood for subwoofer enclosures!
Use AT LEAST 3/4" MDF. Also, that will NEVER be over $25 a sheet WITH tax...unless...it's an ass raping store...
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 02-22-2005, 01:51 PM
or in california..... shits more expensive out there.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-22-2005, 03:39 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
well if Marine grade plywood isnt avalable or is out of your price range and MDF isnt avalable then Particle board is the next on the list. then regular ply wood. but 60 for particle board? ive payed 40 for HDF... HDF=1000% better than particel board.
Old 02-22-2005, 04:57 PM
I would NEVER use plywood for a box.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-22-2005, 06:44 PM
CBFryman's Avatar
Banned
Marine Grade doesnt warp. period. and it wont swell like MDF. and it is slightly more dence than MDF which gives it a lower FS. so it is technically better. but because MDF is good enough little difference is found.
Old 02-23-2005, 06:53 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
If you get real HDF, it won't swell or warp at all. I left an old box outside the shop and it rained hard. Actually filled up the box alot until I figured out where it was. Dumped out the water and everythings fine. Marine grade plywood is OK but it is subject to absorbing freqencies in extreme conditions which is not good. For those lower powered subs you guys talk about though it would probably work.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 02-23-2005, 09:47 AM
ngsm13's Avatar
prolly work for those piece of shit directed's you whore around as well...
NG
Old 02-23-2005, 11:17 AM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
