Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 02-21-2005, 11:25 AM
darrellred darrellred is offline
97 GT AC Recirculation button not working
The button that changes from inside to outside air flow does not work. A while back the radio was changed out but I could not find anything unhooked or disconnected. The light did go on and off for a while but the airflow did not change. Now the light on the switch doesn't come on.
Cruise control doesn't set either. Both could be a vacuum problem?????????
Old 02-21-2005, 06:09 PM
boschmann boschmann is offline
Re: 97 GT AC Recirculation button not working
It's probably unrelated. The switches are known to go bad. The cruise may be a vacuum problem, usually the brake pedal vacuum switch or a leak in the hose near the batttery.
