Old 02-21-2005, 09:30 AM
rickluq rickluq is offline
Banned
rear defrost
Just bought a used 1999 Escort ZX2 - this car has no bells and whistles other than AM/FM stereo. It looks like the original console, but I cannot find the rear defrost control! There is a "blank" on the console right next to the airflow selector knob, which I assumed was where the A/C switch would go if the car had air. Is it possible this is where the rear defrost button belongs? If the answer to that is yes, is it possible that everything is wired up and I just have to install a switch? Is it poosible at all that rear defrost was "optional" on this model???
Old 02-22-2005, 08:49 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: rear defrost
It is possable. I personally thought it was standard. My nova is so old it was an option.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 02-22-2005, 08:55 AM
Banned
Re: Re: rear defrost
[thanks - your radio removal walk thru is very good! I was going to wire a toggle switch under the dash for the rear defrost (it was an option btw), now I will use your instructions to remove the consle and wire it up that way.
Old 02-22-2005, 09:01 AM
chevyn0va1's Avatar
Re: Re: Re: rear defrost
great let us know how you make out.
Old 02-24-2005, 08:32 AM
A. Souphound A. Souphound is offline
Another thought: The rear window defroster pulls a lot of current, and I suggest you hook the (+) side of your switch to the wire harness connector meant for the (optional) defroster. Normally the (+) wire branches off from a fusible link.
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
