Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-21-2005, 02:59 AM
joemathews's Avatar
joemathews joemathews is offline
Pick My FMIC for Me!
Don't get too excited, guys--I'm not buying one just yet. Just doing a little homework (or having you do it, rather ) to get an idea of how much money I'll be spending, and what platform will yield the best results.
First things first: I will be doing an ebay core with custom piping. My goal is to get this all done for under $300, but we'll see if that is possible. I suspect I'll be a bit over that in the end, especially considering couplers and what not. Please keep in mind when considering these options that this will be a daily-driven car, and I will need my A/C operational (FL summers can be killer ).
For a while I assumed I would just get the monstrous 12x24x3 core, but after reading Kevin's warnings about overheating, I've researched a few other options.
These are the options as for as the intercoolers themselves:
1) http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
2) http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
3) http://cgi.ebay.com/ebaymotors/ws/eB...category=33632
4) one of various 24x12x3" cores with 3" i/o, $210 shipped
Cliff's Notes version?
1) $230 shipped, 20.5x9x2.4" core, 2.75" i/o
2) $240 shipped, 21x9x3" core, 2.5" i/o
3) $203 shipped, 20x6.5x3.5" core, 2.5" i/o
4) $208 shipped, 12x24x3" core, 3" i/o
Which do you think would be best suited to my setup (Evo16g turbo)? Would any or all of them leave room for the future, if I decide to go bigger at some point? Would the 3.5" thick core be superior even though it is only 6.5" high?
Throw some stuff out there for me; I'd love to hear what you guys think
1996 Eagle Talon
Old 02-21-2005, 03:50 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Pick My FMIC for Me!
bar and plate if you can...
Old 02-21-2005, 03:54 AM
joemathews's Avatar
Re: Re: Pick My FMIC for Me!
Yeah, good point, Vince. All of the options I posted above should be bar and plate style intercoolers--please correct me if you notice I misread one or more of the descriptions.
1996 Eagle Talon
Old 02-21-2005, 04:01 AM
top two are tube and fin, #3 is a bar and plate.
#4 is whatever...
B&P is a bit heavier, but more efficient. if i ever get a new one it will be B&P.
Old 02-21-2005, 06:25 AM
kjewer1 kjewer1 is offline
AF - Advisor
2 or 3 is the best bet. 12" is too tall for your application, and 2.4" is too thin. And anything but 2.5" in and outlet is going to cost more in the required reducer couplers. Straight sections are much cheaper. It was a toss up between the taller but thinner core and the shorter but thicker core. Hearing that number 3 is bar and plate, I would now lean towards that one.
Adding length increases pressure drop, while adding height or thickness will reduce it (height can be tricky depending on endtank design). It will be easier to get more air to the greater thickness than to a greater hieght. You have a 2.5" pipe vs the height, and 2.5" vs the thickness. What I'm saying should be obvious, if not I can elaborate, though its kind of hard to explain cleanly. Shorter will also allow more airflow to the AC condenser and the radiator. Sounds like 3 is the way to go. 16% less charge side area, hardly enough to offset the reduced risk of overheating in sunny florida.
I would quickly estimate pipes/couplers at ~100 bucks. But that puts you jsut about at your 300 mark. Looks like #3 is the cheapest too? Yeah, 3 is looking better and better.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-21-2005, 11:45 AM
oztofrdm oztofrdm is offline
http://stores.ebay.com/Extreme-Turbo...enameZl2QQtZkm
has anyone on here used one of his intercoolers before, they look to be alittle bit better quality than almost all the ones on ebay.
Old 02-21-2005, 04:31 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
make sure to put back the air ducts and seal the bumper to the fmic and the fmic to the radaitor. that will help with your overheating because it forces all the air to go through the fmic AND the radiator
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-21-2005, 04:48 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
http://www.automotivearticles.com/Ducting.shtml
DSM geek
Old 02-21-2005, 05:17 PM
george536's Avatar
george536 george536 is offline
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Im gonna get this one since its the cheapest and dont plan on doing custom fabrication. Plus it looks really good. Ill cut the black piece off and i think it will let some air in my radiator... I hope.......... my summers suck too
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 02-21-2005, 10:20 PM
he just put this one back up for auction today, this is the setup that i am going to use if and when i get this gsx next week or whenever. Of course after i slap on a ported EVO turbo: ) and the suporting mods.
Old 02-22-2005, 02:11 AM
AF - Advisor
Given the length of that core, you might have to shift it over to the drivers side some if you want to cme through the radiator support for the outlet like the SBR kit. My SBR core was 24 inches long for reference. I'm sure it can be done though. Shorter really is better, if for nothing else to keep the engine bay simple. Fewer couplers also means less leak and blow off potential.
As far as going to a bigger turbo, its also important to remember that larger turbos tend to be more efficient at the same boost. Say 20 psi on the 16g, and 20 psi on the 20g. With greater effciiency, less intercooling is required But since the 20g will have 5 psi more boost capacity, and boost is heat, that is when you will want a bigger core. BUT, at the same time, you will be running race gas if you are running 28-29 psi on a 20g anyway, which will again reduce the amount of intercooling required. My point is that while a larger core would be beneficial, it may not be requried, and I would see if it works with the bigger turbo rather than just automatically upgrade. It may do just fine, and still let you run your AC without overheating
Additionally, Kyle (KPT4321) is a local NEDSM member, and you can pretty much trust everything he says. Very knowledgable.
Kevin Jewer
Old 02-22-2005, 05:33 AM
i got my core and it pretty much covers the radiator. and this was in the heat of the SFVin the summer, where 110 days are not uncommon. my car actually ran a smidgen cooler with the intercooler... go figure...
Old 02-22-2005, 04:35 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Do you think if you get the #3 intercooler would you have to cut the bumper supports? From the picture it seems like you cant keep the fog lights, can you?
The black eclipse really looks nice! I just like how the intercooler looks since its not huge!
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 02-22-2005, 10:49 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Kevin said everything plus more than I would have said, thats why I havent voiced any opinion yet... Plus I know it irritates you!
cavalierchamp: why don't you give me some insightful advice ?
Here is some advice... SEARCH It took me 1.39 seconds!
http://www.automotiveforums.com/vbul...d.php?t=198037
Old 02-22-2005, 11:07 PM
EclipseRST's Avatar
Banned
Originally Posted by joemathews
If I hadn't read that thread when it was written almost a year ago, that would be very useful
I'm referring to the more specific option, Jake. See two posts up : I want you to tell me which one to get so I can defy you and get the other one!
No, I already know that the ricer in you would take the bigger core
LOL!!!
No, I am not running a pussy little 16g like you are! I need a big intercooler! My core is only 24x12x4...
Go with whatever you want... Its your car, your money, and your goals!
