| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
ECU questions
I need a 90 turbo 5spd ecu. what i am woundering is if a 90 turbo awd ecu will work (MD-166262). if not then what is the part # for the 90 turbo ecu. i have not been able to find it.
Re: ECU questions
Did you mean to say auto ECU? You are comparing a 5 spd to a AWD, doesnt really tell us much
The auto ECUs are setup for smaller 390cc injectors on the 1Gs, so it wouldnt work without an AFC or similar to compensate. Hardly worth the trouble, unless perhaps you already have an AFC installed and you're really in a pinch. If you are comparing AWD to FWD, there is no significant difference, they are interchangeable.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
the only thing i asked was the difference between the 5spd and the awd ecu, and thats all i needed to know, so don't go talking to me like i'm stupid
, so many ppl on here are rude. but anyhow no i don't have an auto i have a 5spd and my ecu died so i need a new one and i needed to know which will work. so thx for the reply but next time someone asks something and you decide to anwser maybe you should think about only answering the question they ask and not anything else.
Re: ECU questions
1993 Eagle Talon ES (4g63NA) 14.6 @ 98 mph (110 octane race fuel) -5 Speed Transmission (From a 4g67) -Stage 2 Crane cams -Ported and polished head -Aggresive valve springs -2.5" Custom made exhaust piping -Custom header -Gutted catalytic converter -Bored 0.5mm -Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC) -2g valve lifters (Lifter noise returned, now it a true DSM) -K&N w/modified air canister |
Re: ECU questions
You should listen to Kevin, he knows more than you.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
Re: Re: ECU questions
Couldn't put it better myself "unfuck your attitude", "sort out your fuckery", "assclown"...ahhh...I LOVE IT! Sygma--> You just burned a bridge with one of the smartest guys on here. And when you disrespect him, well, you disrespect a lot of us. I know that I will not do anything to help you out. Oh, and he wasn't rude at all. You did ask a stupid question, do you really realize what you said? Like, how can you get mad about something like that? You seem to be a rather useless addition to this forum.
"You can have everything in life you want if you will just help enough other people get what they want."
