Old 02-21-2005, 12:34 AM
daveid daveid is offline
stumped
i have a 96 ford aspire and it died one day after kinda sputtering. It wouldnt start afterward. Its getting spark, getting fuel, i can tell i has compression, WHATS MISSING?
it just keeps cranking like it wants to go but it doesnt.
any help would be appreciated.
thanx
david
Old 02-21-2005, 07:48 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: stumped
is the sprak timing correct? is it carburated or FI? if its FI it may be an ECM problem.
Old 02-21-2005, 04:15 PM
bjdm151 bjdm151 is offline
Yea you probably wouldn't just lose compression. It definatly sounds like a timing problem. but it could also be fuel. need more input.
Anybody got ten grand?
BJ
Old 02-21-2005, 10:03 PM
Re: stumped
well i know its getting fuel cuz the night it broke down the plugs were fouled out cuz of how much fuel was in them. Its fuel injected and everytime id try to start it the fuel would keep coming in cuz of it being an electonic pump. So i bought new plugs and still nothing.
What do you mean spark timing?
thanx david
Old 02-22-2005, 09:23 AM
ghostguy6's Avatar
ghostguy6 ghostguy6 is offline
Send a message via AIM to ghostguy6 Send a message via MSN to ghostguy6 Send a message via Yahoo to ghostguy6
Re: Re: stumped
thanx david
You want the sparkplugs to fire just before the piston reaches Top Dead Center (TDC) of the cylinder. If your timing is set to soon or too late you dont get a good burn in the combustion chamber, therfor you waste gas and in extreme cases you lose power. If your spark isnt timed at the correct time the air/ fuel mixture will not ignite therefor the engine will not turn over. When you changed the plugs did you make sure you had the correct firing order? Perhaps run some fuel injector cleaner through you injectors and see if that helps and check your timing.
Want to be a mod? Join up at www.mypicgallery.com and PM me.
Old 02-22-2005, 01:24 PM
Re: stumped
sorry i didnt mean to sound stupid but i knew what timing was but i was wondering if spark timing was different.
thanx, ill try it.
Old 02-22-2005, 03:43 PM
CBFryman's Avatar
Banned
Re: stumped
well yo ucant just say timing because you cna advance/retard you spark and cams...
Old 02-22-2005, 05:43 PM
Re: stumped
oic. i sprayed some chemtool in the injecters and it turned over even faster like it wanted to start even more but didnt. and yeah the plugs are in the right order.
thanx
david
Old 02-22-2005, 09:26 PM
MIKE21STRONG MIKE21STRONG is offline
Re: Re: stumped
If It Has A Cap And Rotor Try To Replace Both I Had The Same Problem
Old 02-22-2005, 10:33 PM
Re: stumped
well mine only have like 15k miles on the cap and rotor, and they seem to still be in good condition but i might go ahead and try that.
Old 02-24-2005, 02:34 PM
Re: stumped
cap and rotor look like they havent even been touched. I dont think thats the problem.
thanx
david
Old 02-24-2005, 07:21 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: stumped
HEY!!! Check this before you mess around anymore!!
Check to see that the valves are moving when you crank the engine over. If no valves move, you broke the timing belt/chain/gear. All you have to do to check is take off the oil filler on the valve cover and check that the valves or valve springs move when the engine cranks.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 02-25-2005, 12:54 AM
Re: stumped
all right...will do tomorrow morning.
thanx
david
Old 02-25-2005, 02:01 PM
Re: stumped
well the rockers are moving in there so the timing chain is fine.
