Old 02-20-2005, 10:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Shock Selection
95 Talon TSI AWD
i've been lookin at suspension systems for the past few weeks and i've decided to get some ground control coilovers but there are different setups that they run with, like different brands of shocks. my question is, what shocks are the best? i plan on having a pretty high horsepower car which i'll probably be taking to the track at least a few times and i want to lower it a little bit, and i think i should get some aftermarket shocks as long as i'm taking the suspension out, but i was wondering what's the best to use in this situation?
95 Talon TSI AWD
97 Eclipse GST
Old 02-20-2005, 11:54 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Shock Selection
I use tociko Illuminas, but it seems Konis are probably the best off the shelf shock, or so I hear from people that know a lot more about suspension that I do. I would go with Konis if I did it again. The spring rate has to match the shock valving, and tocikos are somewhat overpowered even at the relatively low 450/325 spring rates I run.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-21-2005, 12:16 AM
Re: Shock Selection
would you suggest adjustable or non-adjustable ones?
95 Talon TSI AWD
97 Eclipse GST
Old 02-21-2005, 06:10 AM
AF - Advisor
Re: Shock Selection
Adjustables. They will have more range than the NAs, and you need that to be able to control a stiffer spring.
Kevin Jewer
