Old 02-20-2005, 10:21 PM
4G63t Power 4G63t Power is offline
Bad night of drifting...
Ok... I was heading out for a night of drifting (just got like 4 inches of snow) and my E brake light/coolant light/and battery light all came on. So i went home... put some coolant in (wanst that low) and went back out. The lights still stayed on as i was going to meet up with some friends and it stalled the first time... Got it started by screwing with the battery. I started driving home and it kept getting worse and worse. Finally it just shut down all together. After a call to triple A I got it towed home. I think it might be the alternator but my alternator light never came on. The guy from triple A said that the car was running off the battery. My check engine light kept clicking on and off along with my cd player/gauges. When it stalled the last time I popped the hood and the manifold was red like it was running pretty hard. Now does this sound like an alternator problem or something in the computer maybe a fuse... I dont know. I cleaned the battery terminals and its still doing it. Any help would be great.
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 02-20-2005, 10:23 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Bad night of drifting...
sounds like a battery/alternator problem
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-20-2005, 10:34 PM
totalDsMmania totalDsMmania is offline
Banned
sounds more like the alternator because it should charge the battery as long as the cars running
Old 02-21-2005, 03:41 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
make sure you are not grounding out any wires from the main fusebox under the hood. i had an engine fire like that...
Old 02-21-2005, 06:32 PM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
Haha I remember that Vince. You got to be careful not to make the same mistake that other ppl have made here, thats why we share our mistakes! It sucks that you didnt have much fun drifting, but make sure your car is ok before having fun like that!
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
